Many times even when I try by pressing twice, only driver door unlock and I will get a divorce if I continue to keep my wife out in the cold. I there any way to change that ? |
Because of your concern, I assume you have a lowline display and don't have the option to change it via the MFD: http://www.myturbodiesel.com/1000q/a...display-VW.htm
If you don't have it, you have to use a VCDS cable and software to adjust the option in the central convenience module. If you need more steps I'll take some screenshots. |
I whipped this up just for you: enjoy and you're welcome. It has detailed step by step instructions on how to enable unlock all doors with a single press of the remote. These are normally options if you have a highline display and all TDI 2009 and newer have highline displays.
http://www.myturbodiesel.com/1000q/a...com-tweaks.htm |
Tell your wife to not pull the handle until you've unlocked the doors or try changing the remote battery?
Unfortunately I don’t have Highline display, and I don’t own VCDS (I need to find out where I can get one and if I can afford it).
Thanks for fast respond and advice. PS. As wife advice goes, I'm not sure if that will work. I'll try to replace batteries thou. |
You need the hex-can for 2005 and newer mk5 cars. http://www.ross-tech.com/Merchant2/m...ry_Code=VAGCOM They sell them in USB and serial cable. http://vagcomlocator.com/tinc?key=cS...ormname=VAGCOM You could also try to find someone local with this vag com finder.
I didn't know this will be so expensive.
Thanks for your info. |
Try using the finder to find a local with the cable.
You can always sell the cable on ebay when you're finished. The used price is $320-300 which makes the cost only $30-50 + ebay fees. here's an example. http://cgi.ebay.com/ebaymotors/Ross-...motiveQ5fTools |
Wifes happiness <, >, = $349?
Since you have a 2006 Jetta (from your profile), you can use the Micro-CAN Interface
http://www.ross-tech.com/Merchant2/m...ry_Code=VAGCOM for $249.00 Wife happiness just got less
