Old 11-13-2011, 07:29 PM
Car: 2006
Default Questions Replacing Cam on BRM?
I pulled the valve cover off last night and found that the cam and lifters were showing a lot of wear. My question is this. Do the injector rocker arms need to be adjusted after the cam install? Some cat engines i've worked on the injector height actually controls injection timing. I was also wondering if anyone had used the kit from idparts. Its the cheapest i've found @$695.
Old 11-13-2011, 10:29 PM
Car: 2006 jetta
Default Cam
I'm in the same boat as you right now. Worn out cam, but i'm looking at the Colt stage2 cam. Read good things about it being a better profile to live longer, stronger material, and good for 15hp/30ft.lbs. Just trying to figure out where is the best place to get all the stuff. Seems like there's a few suppliers that supply very good parts.
Old 11-14-2011, 11:53 AM
If rocker arms were replaced yes, if not no but it couldn't hurt. Yes the adjuster nut has a role in fueling. See the article in exclusive section for specs on adjusting height.
Old 11-16-2011, 11:23 AM
Car: 06 TDI Jetta
I would say you probably should. If the injector lobes base circle diameter on the new cam is different, you could have a problem.
Cam lift is determined by the difference between the lowest part of the base circle and the highest part of the base circle and not so much by the diameter.
Franko9 on Fred's TDI Club has a quick and dirty way to adjust the injectors. Chitty may have the "quick and dirty" procedure in his ever growing how to articles, as well.
Old 01-19-2012, 09:37 PM
Car: 2006
Default same boat
just pulled mine down,,cam and lifters gone, this is the last thing i wanted to spend the weekend doing.
