Old 03-15-2011, 06:51 PM
Car: 2006 Jetta
Default Instrument Cluster Swap
Hi,
I own a 2006 Jetta that has a bad fuel gauge, I changed the floater, checked the cables and the gauge would not move, Ifinally found a used instrument cluster and tried it and immediately the gauge moved, meaning that the original panel needs to be replaced, unfortunately the immobilizer needs to be programmed, any ideas? I don't want to spend too much money but I do want to know how much gas is left on my tank. Hope someone can help
Thanks!
Old 03-15-2011, 08:23 PM
Here's the immo faq to have a look at but can the fuel gauge not be removed seperately or is it one of these things that can't be done?
http://www.myturbodiesel.com/1000q/m...W-Audi-FAQ.htm
Old 03-16-2011, 10:47 AM
Car: 2006 Jetta
IDK, I'll try and take apart the one I have now and see if it's possible to swap, it might be but I am really not sure, I'll keep you posted. That would be easier than going thru the wholewrite up, especially with no vcds or anything like that.
Old 03-16-2011, 01:17 PM
Car: 2006 Jetta
Is there any way to swap the Instrument Cluster Immobilizer??? Anybody?
Old 03-16-2011, 01:58 PM
If you mean swap the guts and case, yes. If you mean just remove the immobilizer function of the instrument cluster, no because to the best of my knowledge it;s built into the board.
Old 03-17-2011, 12:20 PM
Car: 2006 Jetta
Ok last night I decided to do my best to finally make this work.
I took apart the fully functional dash and tried to remove the fuel gauge which I tried and unfortunately could not get it off and I finally fd-it and now it looks like it does work anymore since before when I plugged in the dash the car would not turn on, but the gas gauge did move, now the gas gauge just stays still, LOL so I ended up f-ing it up.
What I did try is to swap the front part of the dash and plug it in to the back part and it seems the immobilizer is on the back because I could get the car to start although I got some funky numbers and characters on the dash.
So I ended up doing some more experimenting, and I plugged the dash without the plastic front cover and noticed that even if I move the gas gauge manually to the right it would go back and reset to empty and would move slightly to the right, which got me thinking it might not be the gauge, but what did baffle me is how the gauge I messed up did seem to work even though the car would not start because of the immobilizer.
So really I am not sure what else to do, right now I'm just going by my gut and filling up the tank more times than I should because I don't want to be stranded with no gas.
I am thinking of getting Vag Commander, do you think that could help?
Thanks!
Old 04-11-2011, 12:35 PM
Car: 2006 Jetta
Ok, here goes the latest,
I have a faulty Gas Gauge on my Cluster Part Number 1K0 920 952 C, everything else works great, vag com gives me fault code
00771 - Fuel Level Sensor (G)
010 - Open or Short to Plus
Vag Commander 5.1 can read the immo Pin and mileage with no problem.
So I decided to get a another cluster from fleabay, I bought one with PN 1K0 920 952 K, first thing I noticed when plugging it in to the dash is the immo light (Key & Car) is not flashing, tried turning on the car and of course couple of seconds on then turns off, so I connected Vag Commander and get a "cannot read security access code. please reset cluster and try again" error, I reset the cluster and again the same thing, I can read the mileage but cannot change it, also I noticed after I read the cluster and get the error I reset but the cluster stays exactly the same, so I don't think it resets itself.
I read with Vag Com and it says cannot communicate with immobilizer.
Also noticed all the gauges seem to work, especially the gas gauge which is my concern, so this would rule out any problems with the sender or wiring, I have some sort of short on my original cluster.
Any Ideas on either fixing the original cluster or reading the immo pin on the fleabay one?
Thanks!
Old 04-11-2011, 01:12 PM
I had the same problem, go to read/write immo data and there's another field where you can read the SKC, see the main immobilizer FAQ article. I would also not try to change the mileage. It's illegal and as you have found out, these types of products are best for reading only because they can be buggy. Sometimes people try to write and it bricks the unit.
Old 04-11-2011, 02:58 PM
A friend I work with used to work for VW and they used to change the mileage back to zero on new cars just to remove the delivery mileage this can only be done once thats if the mileage is below 60 miles.
I tried it on a Golf TDI a couple of months ago and it doesn't work as it shouldn't else every car sales will have VCDS.
Old 04-11-2011, 08:52 PM
Car: 2006 Jetta
I really dont care about the mileage, the big deal right now is the fuel gauge that I want fixed, where exactly on vag commander can you retrieve the SKC i cant seem to find it
Thanks!
