Here is the freeze frame data from VCDS: 000401 - Fuel Pressure Sensor (G247): Implausible Signal P0191 - 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 2 Fault Frequency: 1 Mileage: 61249 km Time Indication: 0 Date: 2019.14.24 Time: 09:08:18 Freeze Frame: RPM: 1403 /min Speed: 0.0 km/h Lambda: 31.6 % Pressure: 232.0 bar Pressure: 536.0 bar Pressure: 952.0 bar Temperature: -2.7°C 000135 - Fuel Rail/System Pressure: Too Low P0087 - 000 - - - MIL ON Freeze Frame: Fault Status: 11100000 Fault Priority: 2 Fault Frequency: 1 Mileage: 61249 km Time Indication: 0 Date: 2019.14.24 Time: 09:08:19 Freeze Frame: RPM: 1541 /min Inj. Quantity: 35.7 mg/str (no units): 4.0 Pressure: 760.0 bar Pressure: 120.0 bar Temperature: -2.7°C Tank Cont.: 52.9 l |
![]() How come your messing with it as it should be under warranty? EOBD II Error Code: P0191 Fault Location: Fuel rail pressure (FRP) sensor - range/performance problem Possible Cause: Wiring. Fuel rail pressure (FRP) sensor. VAG Error Code: 16471 EOBD II Error Code: P0087 Fault Location: Fuel rail/system pressure too low Possible Cause: Power Loss. Fuel pump (FP). Fuel pressure regulator. Fuel supply pipe blockage. Mechanical fault. Possible Solutions: Check Measuring Values for Fuel Pressure. Check for bent/squeezed Fuel Lines. Check Low Fuel Pressure System for Leaks. Check Fuel Filter & Filter in Fuel Pump. Check the Fuel Quantity supplied by the Fuel Pump. Special Notes: When found in 2.0l TFSI: Check Fuel Pressure. When found on 2009 Audi 3.2 FSI AVS Engines, if DTC 000022/P0016 is flagged, please see TSB 15-09-04. As taken from my Free EOBD II Error Codes software
Hi,
I had similar problems in the past. Read about it on the other forum or PM me. http://forums.tdiclub.com/showthread.php?t=283393 |
Check the fuel quantity regulator for metal particles.
