Old 09-16-2011, 08:59 AM
williamgd2's Avatar
Car: Jetta 2010
Mods: Frost heater.12volt switchable fuel heater on fuel filter canister.Oem type wing.
Angry 2010 Jetta rcd510to rns510 radio mod with a problem
I did the radio swap fom the factory rcd 510 to a brand new fully updated rns510 and did the coding and the steering wheel controls and other features work great except for the voice command feature, The mic button does try to control the unit but it doesn't hear or reconize the command and I have tryed all the right commands. does anyone know what could fix this? It is a option I would really like to have if possible. Thank You
Old 09-16-2011, 09:27 AM
Car: 2010 VW JSW
Mods: APR Intake, PDE Downpipe, Banks Exhaust, Malone Stage 2, Koni Coilovers w/H&R Springs, Big Swaybars
Which Bluetooth module do you have? You may need to swap in a 9W7
http://www.mediafire.com/imgbnc.php/...d648a44a5g.jpg
2010 VW JSW TDI with a few mods...
Old 09-16-2011, 01:02 PM
williamgd2's Avatar
Car: Jetta 2010
Toeball I don't know which bluetooth I have I will have to look but the unit responds to the mic button but doesn't hear or recognize any commands.The dealer who sold me the unit says I can rerout the mic wire from the bluetooth to the rns510 and use the mic out on the rns510 to the mic in on the existing bluetooth. Unless someone who really knows that won't work thats what I plan on doing. I went to check your link out but its dead.
Old 09-16-2011, 03:37 PM
Car: 2012 Passat SEL TDI, 2010 Jetta TDI w/DSG
Mods: Gentex auto dim mirror
Did the existing sharkfin antenna work for GPS?
Old 09-16-2011, 07:25 PM
I'm not sure if the sharkfin is different if you have nav from the factory but there's no wiring for it anyways. The solution is to add an aftermarket antenna under the dash. It takes 5 seconds to stick it under there vs. running wire to under the headliner so I wouldn't recommend using a sharkfin even if it did work. The aftermarket antennas are really cheap too, like $5-10 so it's well worth it.
Old 09-16-2011, 07:33 PM
I have found numerous sites that sell these, any recommendations for a source?
Old 09-17-2011, 02:01 PM
Sell what, the RNS or the antenna? Check out mfd3.com, a site sponsor for any VW nav related accessories
Old 09-18-2011, 06:46 PM
williamgd2's Avatar
Car: Jetta 2010
The splicing into the bluetooth mic to radio worked all functions on my rns510 work great. http://www.my-gti.com/1234/volkswage...-voice-control Here is the link to the job details for those that need it.
