Old 09-06-2011, 01:06 PM
tf06jettatdi's Avatar
Car: 2006 jetta tdi
Mods: none, all stock
Default 06 jetta tdi camshaft position sensor issue
hi all,
having a issue starting my 06 jetta tdi. i have been looking through post and found one on another issue but suggested to disconnect the camshaft position sensor if you cant start you engine...i did that and it allowed me to start the engine...it took a little longer to start but it did start....so now i am trying to figure out what is wrong...is my camshaft position sensor bad?...is there a way to test the sensor or wiring....please help...
thank you
tom
06JETTATDI
Old 09-08-2011, 01:07 AM
Was the rear main seal replaced or removed recently?
Do you have VCDS? You can use that to check camshaft sensor. Possible things that could cause a problem other than sensor are timing belt, cam wear, wiring problem.
Old 09-14-2011, 11:30 PM
Car: 2006 jetta tdi
no on the rear main seal...i do have and VCDS
what group in the VCDS do i check on?
what values am i looking for in testing my camshaft position sensor?
camshaft and lifters replaced 20k ago
timing belt replaced 30k ago.
thank you
tom
06JETTATDI
Old 09-15-2011, 11:47 AM
Car: 2006 jetta tdi
ok,
here is my fault code from the VCDS
Thursday,15,September,2011,08:38:44:49707
VCDS Version: Release 10.6.4 (x64)
Data version: 20110418
Address 01: Engine Labels:
Control Module Part Number:
Component and/or Version:
Software Coding:
Work Shop Code:
VCID: 55AB98FF8591
2 Faults Found:
012296 - Camshaft Position Sensor (G40): Signal Out of Range
P3008 - 000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 7
Mileage: 314089 km
Time Indication: 0
Date: 2000.00.00
Time: 22:14:58
Freeze Frame:
RPM: 882 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.39 V
Bin. Bits: 00001000
Idle Stabilization: 0.0°KW
(no units): 35.0
012295 - Camshaft Position Sensor (G40): No Signal
P3007 - 000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 78
Mileage: 314089 km
Time Indication: 0
Date: 2000.00.00
Time: 22:23:01
Freeze Frame:
RPM: 924 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.31 V
Bin. Bits: 00001000
(no units): 38.0
06JETTATDI
Old 09-20-2011, 03:09 PM
Car: 2006 jetta tdi
this is the error when i have the cam position sensor plugged in...and wont start
06JETTATDI
Old 09-21-2011, 04:09 AM
Car: 06 TDI Jetta
The part the cam sensor sees is what the cam sprocket bolts to. As I recall the sensed part protrudes slightly over the top of the valve cover.
Is it possible you damaged a wire or knocked the sensor out of position or damaged it or the part that is sensed, somehow when changing the cam?
Old 09-21-2011, 02:11 PM
Car: 2006 jetta tdi
the cam was replaced 20k miles ago and the car was starting just fine till a week or so ago....i have to unplug the cam shaft position sensor to get the car to start now....is there a way to test the cam shaft position sensor? is there a way to test the wiring? voltages? resistences?
tom
06JETTATDI
Old 09-21-2011, 04:31 PM
VAG Error Code: 19464
EOBD II Error Code: P3008
Fault Location:
Camshaft position (CMP) sensor - signal limit exceeded
Possible Cause:
Insecure rotor.
Camshaft alignment.
VAG Error Code: 19463
EOBD II Error Code: P3007
Fault Location:
Camshaft position (CMP) sensor - no signal
Possible Cause:
Air gap.
Insecure sensor/rotor.
Wiring.
Camshaft position (CMP) sensor.
brings up that crank angle sensor and camshaft sensor are both Hall type sensors.
Old 09-22-2011, 12:07 PM
Car: 2006 jetta tdi
thanks Keith, will test sensor & post findings.
Tom
06JETTATDI
Old 09-24-2011, 02:22 PM
Car: 2006 jetta tdi
test results
pin 1 to pin 2 = 4.95 volts
ping 3 to earth = .45 volts on average
so it looks like i am within what they said on the video....can my timing be off...i am going to check that tomorrow
tom
06JETTATDI
