Need to know why it broke before a good answer can be provided.
It's pretty rare for that to happen I think.
2005 Passat 2.0 TDI PD unchained, steel glowplugs, new timing belt and motor mounts, tranny serviced regularly, etc... |
Nope... we hear about this fairly often - usually from people in the Rust-Belt...
Were you in the process of replacing the bushing or did it just happen to break? You may need to lower the subframe, although there may be other options... I wouldn't drive too much... and not at high speed... Yuri |
Thanks. I was NOT I had them replaced by a Mechanic. Last month. I believe he over did it? He used an air ratchet. The bolt is gone not just busted gone. The hole is clean. Looks like when he did it it must have stripped clean. One nice thing this car has done when breaking. Thanks. Loving this place more & more! |
Is the welded nut still in place? They sometimes break off... if that was the case, the mechanic may have replaced it with a regular nut, which may have let loose...
What's not to love? Yuri |
Nope I was there it was the one that came out just little smother and rusty I hope they TDI guy I am suppose to see Saturday can fix it? Might just need to be tapped out and a new bolt ? I hope so this Lemon has been a PITA since I got it chipped. Or maybe the TDI guy I was bringing it too???? Again thanks. Love the How too threads as well ! Fred |
I would think that use of the correct alloy would prevent it in the future.
Cheers, Yuri |
Yes and it's been corrected, just like the OP should correct his with better hardware...
They TDI person that I was suppose to see Saturday seems to have
![]() Not sure? But I am having a shop in Winsted CT re tap the hole and fix this annoying Issue. Thanks for advising that it was OK to carefully drive the car to & from work. Fred |
