Old 01-29-2012, 11:18 PM
Car: 2000 Jetta TDI
Default Power loss at 3K RPM MK4 Jetta
Hi All,
I'm new to this forum. I love the MK4 Jetta TDi so much, I bought 2 of them, one for me and one for my son. When I drive the 2 cars back to back, I notice a pretty substantial power drop at around 3K RPM in my car. It is more noticeable in higher gears.
I have cleaned the intake manifold and changed all the vacuum lines. I have also done a smoke test for leaks with no success. It sure feels like a boost leak of some sort.
Any insight would be appreciated.
--Navid
Old 01-30-2012, 12:13 AM
Possible, could also be fueling issue since you say it's more noticeable in higher gears. Check out the low power article in the FAQ and start looking around.
Old 01-31-2012, 12:37 AM
Car: 2000 Jetta TDI
Thanks! I'll start looking around. I think it's more noticeable in higher gears because the WHP is lower in higher gears and lack of it is more noticeable. Also, it picks back up around 3500.
--Navid
Old 02-02-2012, 12:05 PM
Car: jetta tdi 1999.5
Originally Posted by Navid View Post
Hi All,
--Navid
Maybe you have a sticky turbo vanes, or the actuator is bad.
Old 02-02-2012, 10:49 PM
Car: 2003 Jetta GLS
Mods: Panzer Plate, FMJ, Block coolant heater
Are you throwing and CEL codes? If you replaced the vacuum hoses is the check valve the right way around? it's color coded. Don't ask me how I know this - but it makes a big difference in power.
Old 02-06-2012, 07:15 AM
Car: new beetle
my 1999 new beetle have the same problem and the trouble was the MAF
Old 02-06-2012, 10:24 AM
Car: new beetle
Please add 1999 to your car spec?
