Old 04-03-2011, 11:38 PM
Car: 2005 Passat TDI
Mods: Bone stock
Default oil residue on intercooler pipe boot
Hello all,
Today I performed the TB, waterpump, tensioner, idler and serpentine belts replacement on my 2005 Passat TDI GLS. I noticed when I was under the car that on each side of the front end of the car there are rubber pipes that are connnected to a steel tube that runs across the bottom of the core support. I found some oil residue around the joints in these boots. I know these boots have to do with the turbo/intercooler system but, where is this oil coming from and should I be alarmed by its presence?
There was not a huge amount of oil there but, just enough to attract dirt and road grime. Is this something out of the ordinary?
I strongly suggest the dieselgeek TB kit and crank/cam locking tools.
Old 04-03-2011, 11:48 PM
Perfectly normal, it's just a bit of oily residue that gets blown through from the turbo, if you notice your oil level starts disappearing without any sign of a leak I'd be concerned.
Old 04-03-2011, 11:50 PM
Mods: Bone stock
Thanks Seat I appreciate the advice.
Old 04-03-2011, 11:53 PM
No worries, these things can be a bit alarming when you don't know any better but you can also take off the turbo hose that goes upto the inlet manifold and check for excessive oil.
Old 04-06-2011, 09:53 PM
Car: New Beetle
Oil in these places is normal. You may clean the intercooler ductwork with dawn dish washing detergent. and reassemble. Note it will get oily again.
Old 04-06-2011, 10:08 PM
Well it's different for an intro
