I don't know if there's a common point on the passat to look at but I would check all the hoses where the clips are in case one has rubbed through, you might also see some sort of stain where the coolant's been leaking, sorry I can't be more helpful but I'm sure others will know something.
Try the heater hoses. Remove the engine cover (3x 10mm nuts) and look for white spray or pink residue. Worst case, pressure test the coolant tank and it should help reveal any leaks.
Also, post moved to mk4 section since this is a specific question vs. just an intro.
Could there be a similar coolant flange problem that happens with the Jetta here? That seems to be a regular problem. I'm not as familiar with the Passat, though.
