Old 02-16-2012, 10:20 PM
Car: 2000 Vw Jetta TDI
Mods: pp764 nozles, custom 2.5'' downpipe, cold air intake, egr delete, race pipe, upsolute tune
Send a message via Skype™ to oil4blood
Default Help needed with alh injectors
hey all bit of a newbie here, i recently lost the timing belt on my 00 jetta tdi alh engine code. other then the stock chunk of aluminum the head is brand new but while the head was off being rebuilt i disassembled the injectors and soaked them in carb cleaner to remove the carbon and other gunk. i took pictures of how they came apart so that i could put them back together correctly. long story short got the car all back together and running but once i get it up to about 2k it misses a bit. so i thought after a timing belt job the injection timing was off a bit, took it down to the dealer had them check it and they told me it was spot on so tonight when i got home from work i took the injectors back out and measured all the parts getting each injector as close to each other as possible. put it back together and now its worse so dose anyone have any knowledge on the subject or specs? any help would be greatly appreciated
Old 02-16-2012, 11:08 PM
Any chance you mixed them up? or did you soak them all seperately? You might need to get them recalibrated.
Old 02-16-2012, 11:24 PM
oh i know there all mixed up thats what im tryin to sort out
Old 02-17-2012, 12:11 AM
Whoops, sounds like you'll need to get them setup by a pro, they're probably dribbling fuel all over the place. They're a bit tricky because they're 2 stage injectors, the initial stage gets things going then the main injection happens and I expect all that is messed up. Personally I'd speak to someone like kermatdi and ask how much they'd charge to sort them out or find a second hand set maybe.
Old 02-17-2012, 08:14 AM
yea im lookin into in now what do you think of these? http://www.hansautoparts.com/Product...ectors-205.htm
Old 02-17-2012, 01:22 PM
Avoid him like the plague, if you search prothe on the tdiclub you'll see why.
Best to stick with trusted vendors, you could try franko6 on here or the tdiclub, I'm sure he can pop test injectors or if you fancy a bit more oomph try kermatdi or drivbiwire. I think there's probably others but they're who i used and have had no problems.
Old 02-17-2012, 02:30 PM
YMZ YMZ is offline
Car: Jetta 2003, Golf 2001
Ditto...
There aren't too many places that can reliably set the pressure points on these injectors... Send them off to http://dbwllc.net/default.aspx ("drivbiwire") or Frank Irving... frankstdis at sbcglobal dot net
Yuri
Old 02-17-2012, 06:32 PM
from all i read yes he is a bit sketchy but.... i havent seen anything about his injectors and hes got a 2 year warranty behind them so im thinking about getting them and seeing how it goes because im a little strapped for cash at the moment so idk what to do!!
Old 02-17-2012, 07:26 PM
YMZ YMZ is offline
"Sketchy" ... I would use other adjectives...
If you get an injector that doesn't atomize the fuel properly, you could easily burn a hole in your piston... You don't want to go there... (although if you've fooled around with your injectors you're already in danger of having something go very wrong...) Perhaps a local diesel shop could get your injectors working after a fashion... it's doubtful they'll get it right, but they may work...
Good luck... you know what we all recommend, but it's your car...
Yuri
PS: with regard to the "warranty" from Prothe... please find me the screen name of anyone who's ever gotten warranty coverage from him...
Old 02-17-2012, 07:36 PM
It wont cost much much just to get them recalibrated and cleaned, I'd seriously check that out first.
What ever you do, DON'T buy those nozzles from him, you will come to regret it. He will give you a warranty but he'll then find some way to get out of it when it al goes wrong. There are just sooooo many threads on his stuff being utter crap and him being totally immoral.
