will i have to bleed my clutch fluid now, my clutch peddle does nothing now, but my breaks seem to work fine. has anyone had this before |
tried to bleed system might have been a little air, goinig to get a hose now.
after bleeding clutch still no pressure on clutch pedle |
I've seen it mentioned a few times now, it's usually one of the cylinders, either the clutch master or slave. Have you checked there's nothing broken at the pedal?
just happend to me last week after driving from FL to detroit on 2000 jetta tdi. Thought it was my slave cylinder ended up being my through out bearing on clutch. After u take off slave cylinder try to look inside trans to see if any loose parts etc in there
