Old 08-18-2012, 12:53 PM
Car: 2005 VW Passat TDI
Default HELP-Broke Fins on Fan Clutch
I'm new and currently working on my car so I don't have to time to do a thorough search. MY question is if I broke 2 fins on the fan clutch while trying to get the fan off, will that cause out of balance issues when I put every thing back together. I discovered that I can get the bottom bolt out through the hole made by the broken fins, but really need to know if I now have to replace the fan clutch or will it be good as is. Thanks for any help.
Old 08-18-2012, 07:32 PM
Car: 2005 jetta tdi gls 1.9
I didn't know that you have fan clutch, can you send picture.
If you do which I don't think you do, let it spin and see if you see any unusual vibrations, if not then I would let it go.
Old 08-18-2012, 08:51 PM
Are you talking about the fan blades? if so then yes, you'll need to replace it or more things will break with the vibration.
Old 08-18-2012, 11:44 PM
LOL with 2 blades broken out of 3 not much left to brake even with the vibration. Anyway what would that thing be called? Maybe weedwacker fan.
if you research this forum you will find post where I replaced complete radiator fan asembly (2 brand new fans and fan shroud) for 118$ and free delivery. I even posted a link to the site.
Old 08-19-2012, 01:56 PM
Yes it'll be out of balance but at this point I'd put it on and fix once the bearing goes bad. Replace now or replace later. For all you know it could last another 5 years.
Old 08-19-2012, 04:01 PM
I'm not talking about the plastic fan, I am referring to the cast aluminum hub that the fan bolts to, it has the fan pulley behind it.
Old 08-19-2012, 06:02 PM
Oh I see now,
if it's the same like on this picture I wouldn't worry much, especially if broken fins aren't next to each other.
http://www.google.com/imgres?q=passa...r:0,s:62,i:276
but if it starts to vibrate you have nothing to lose and can try to grind the other two on the opposite side and that should bring it to close balance.
