Thanks |
Yes, replace all the plugs. Just be careful they can strip out easily. If the code still comes up replace the harness. That was my problem. I made my own harness to save some money. Worked great. It's been over a year with no more code.
![]() Eric |
Also, if you switch the plugs to a different hole then you can determine if it's the plug or the harness. IE....did the code change to a different cylinder.
Be very careful with the plug extraction....they are alum, as is the head. I worked mine back and forth to free them up. Put a little non-seize on the threads before installing the new plugs and remember that they are torqued to a VERY low value....sorry I don't have the number handy, but a search should provide an answer for you. |
