I understand now that it is under the top cover of the pump...is there any write-ups for that, and where can i get such temp sensor (other than the stealer) ? most current parts store dont list such sensor...only coolant sensors. thanks ! |
See dieselgeek.com He has everything you need to change the sensor, dont forget the special socket you need to remove the top cover, he has that also.
thanks...i also found a write-up on the "other" forum...
http://forums.tdiclub.com/showthread.php?t=75308 how common is this to fail, and show only 91 deg ? pump felt cold to the hand when i did this...can it get that much hot (120-130) even in cold climate ? Last edited by patallen; 12-17-2010 at 05:50 PM. |
![]() http://forums.tdiclub.com/showthread.php?t=75308
