Old 06-01-2012, 03:15 PM
Car: 2001 Jetta TDI
Default air intake missing "snow screen" plus a host of issues
I have a host of issues and tests to run so I'm not sure how many to bring up in one post. The car came with an aftermarket air intake so I found a TDI stock air intake that is now in place along with a new Mann filter. The airbox came with a MAF (as well as having the original MAF).
I noticed, after reading the post about cleaning the snow screen, that I'm missing the snow screen. The snorkle is there, bolted to the fender, but the other end, opposite the airbox, there's a gap between the snorkle and the location that I determined channels the air into the box.
Should I find this part before I test the MAF as outlined in the write up?
I replaced the turbo actuator because the car came with a new one (the old one was deteriorated). I installed it, along with a new vacuum line, but still need to make sure it's adjusted properly via the write up I found for that.
I have no "woosh" that I expected with a turbo. I have slow and steady power and constantly have people travelling behind me go around without patience when accelterating from a stop.
VCDS shows actual boost not matching expected boost. I have a new N75 valve that I can install, but thought I should first make sure the acuator is adjusted properly.
Also had a ton of oil (like 1/2 quart) in the intercooler - and from what I've read, it's normal to have some oil, but certainly not normal for the amount that came out. I replaced crankcase breather pipe and rubber grommet into valve cover, but not the actual valve before I discovered the oil.
Today, after a fresh oil change and after driving about 200 miles, the oil level is down just below the low oil mark. Have not yet pulled the lower intercooler hose to see if any oil accumulated there, but I suspect that could be where the oil went.
Right now, CEL is not on, but VCDS has found a recent code - P1556 Charge Pressure Control, negative deviation, intermittent.
Sorry for bringing up so many different things in one post, but I know the system should work as a whole, and I'm sure there could be some issues that directly correlate and others that do not.
Thanks for any input on where to start.
Old 06-02-2012, 02:01 AM
snowscreen is for keeping big stuff out of airbox and snow from soaking air filter. Won't affect power or make MAF fail since air filter is filtering everything downstream of it like the MAF. Not hurting anything unless it's clogged.
yes, adjust actuator before messing with other turbo settings, I have a feeling it'll help a lot, esp since you have that code. adjustment is crucial to prop turbo function
so how much oil was consumed in 200 mi? After changing oil, it does take some oil to circulate in filter housing and in engine so expect it to go down slightly. If it gets really bad and is going through the turbo you could be coming up to a runaway. see FAQ http://www.myturbodiesel.com/1000q/s...ine-how-to.htm Maybe people are passing you because car has lots of smoke?
Old 06-02-2012, 06:40 AM
Car: 2001 Jetta TDI
Thanks for the reply. Will work on actuator adjustment first - which will have to wait until Sunday and will post progress.
Old 06-03-2012, 04:05 PM
Car: 2001 Jetta TDI
Actuator does not move when the car is started. Disconnected the vacuum line from the N75 valve and brought it down the the ground level. Hooked up a mityvac and applied vacuum in increments and noticed the actuator moving in roughly the correct amount as per the parameters in the write up "how to diagnose, test, or replace the VNT turbo acturator".
Removed the N75 valve, tested the resistance with a multimeter and it came up 16. something. Installed a different N75 valve (which is supposed to be a new and/or working unit) and replaced several vacuum lines. Tested it for resistance - similar to the first one. Removed EGR solenoid and tested for resistance. Again, similar numbers. Can you verify what the nuumber should read for a correctly working unit?
I thought I could test for vacuum coming directly out of the N75 valve using a mityvac, but the needle did not move when I started the car. i hooked it up in replace of the vacuum line going to the actuator. Not sure if my thinking is correct on this.
Hooked back up everthing with the "new" N75 valve, had someone start the car while I watched the actuator and no movement.
Also looked for and found oil in intercooler (as I suspected I might) about a cup or more of oil by removing the lowest short rubber hose.
I began to read up on how to look for boost or vacuum leak check thinking since there seems to be no vacuum from N75, perhaps there's a reason.
At this point, I'm not sure if I should continue to drive the car during my 110 mile commute.
Just to re-cap - car has about 300,000 miles with little to no past maintenance history. I've changed the oil with Castrol Edge 5W40 and used a Mann oil filter. Replaced fuel filter with Bosch, reinstalled OEM airbox with a new Mann filter. I did do the MAF redline test, and the car could easily make it to the redline. My last fuel economy MPG check came up around 53 MPG.
Thanks for any input!
Old 06-03-2012, 05:39 PM
If someone revs the engine, does the vac gauge hooked up to n75 move? not sure what resistance is.
a cup or more of oil in the intercooler is more than I would like to see...if it's not coming from the crank case vent hose it's coming from the turbo. Esp since that was in only 200 miles.
Old 06-03-2012, 08:48 PM
Car: 2001 Jetta TDI
I was checking the ohms with a multi-meter (resistance). There is no vacuum at N75, not even a little with increase in revs.
I discovered the clamp on the larger diameter black hose coming from the vacuum pump was loose. I replaced the clamp but the metal tube coming out of the vacuum pump that the hose / clamp attaches to swivels and by monitoring the vacuum from the 3mm (?) line that goes to the first T ( the line that comes out just at the check valve just before heading to the brake booster), I can see fluctuation in the amount of vacuum just by twisting the metal tube. I assume this metal part is not supposed to be moving and my guess is, by the time the vacuum is supposed to reach the N75 valve, there's not much left.
Does this indiacate a need to replace the vacuum pump? or is it normal for it to twist.
I'll do some more digging with checking vacuum levels at different locations as the lines start to T off.
If I haven't had any vacuum and VNT actuator movement while driving due to this issue, wouldn't that prevent me from highway speed (65 with cruise control, no problem) and/or would this be the root cause of so much oil ending up in the intercooler?
Thanks for your feedback and assistance.
Old 06-04-2012, 12:41 AM
can't remember if it's normal for it to twist but I dont think so. Should not cause loss in vac. Shouldn't be related to oil loss but fix 1 thing at a time and see what happens.
Old 06-04-2012, 06:06 AM
Car: 2001 Jetta TDI
Thanks, will post progress as it happens.
Old 06-08-2012, 02:07 PM
Car: 2001 Jetta TDI
Default some success
After deciding that the main vacuum line out of the vacuum pump is suspect of leaking some vacuum, I used some high temp RTV silicone around the metal outlet tube to make it less wobbly and hopefully maintain better or correct vacuum to the rest of the components.
Hooking all of the vacuum lines back up the way they should still did not produce any vacuum (at idle) to the N75 valve, but I made a little progress, measuring vacuum with mightyvac with the engine running, I think there's a leak before the vacuum reaches N75.
Then, after more research, decided to bypass everything and hooked up the main (small) vacuum line (just before brake booster) directly to N75 and drove the car and actually felt and had real acceleration for the first time since driving the car. I consider this quite a break through. VCDS confirmed specified boost and actual boost nearly matched - instead of before where actual boost would decrease instead of increase with higher RPMs.
Now, to figure out where the vacuum leak is - somewhere between the "main" vacuum line mentioned above and N75 valve for turbo actuator.
I know there are several T and Y connections. Has anyone had these fail? Is it also possible to have the other valves leak (anti shudder - I think N239) or N18 (EGR) as opposed to actual failure (electrical). I have no other VCDS error codes except for intermittent charge pressure control.
The anti shudder valve is not secure to the car. I'm not sure where it's supposed to be, but the person before me used a zip tie to keep it from moving too far.
Also, if, for some reason, the EGR is not functioning the way it should, can that cause a lack of vacuum at N75? It seemed to hold vacuum when I connected a mighty vac to it.
I also tested the vacuum storage container - I applied vacuum to it and the vacuum did not appear to leak out.
Once the car is back on track to working correctly, I'll take the time to make sure the actuator is adjusted correctly.
Thanks and I hope someone can benefit from the dialogue.
Old 06-10-2012, 11:22 PM
Car: 2003
Thanks I didn't know that either!
