I could see there being a little bit in there but no way it should be able to backfill the whole pump and the brake booster line. When the engine is running that vacuum pump should be providing more than enough pressure to stop any oil from trying to migrate out that way. If the pump is worn to the point where it doesn't provide much suction (and thus outflow) it might leak in or if the top of the head where the oil is supposed to drain back into the block is somehow clogged up perhaps an inordinate amount of oil is collecting up top and when the engine is stopped it drains back through the pump?
I'm thinking if the vacuum pump isn't working right you'd notice all sorts of symptoms, hard braking, rough running, turbo issues, cel codes galore. |
Thanks for the reply, i installed a new turbo, all hose's and lines, ect.....
N75 & 109 are replaced, when I get it running i will post the results! |
I cleaned it out and re-installed, my vacuum situation is way better now. will remove it in a few days and see how clean it is.
