all turn signal lights work. However when i turn my headlights on, the rear turn signals do not flash but my break lights flash. This also causes the front blinker to blink twice as fast. Additionally when i hit the breaks without the flashers on, all of the turn signals turn on at about half brightness and stay steady on. This still occurred when i removed the relay that controlled the blinkers. i haven't been able to find anything like this and every one i asked didn't have any solutions. i checked the fuses and they were all still good. Any ideas would be greatly appreciated. Thanks, Rich |
Welcome to the forum Rich.
![]() That sounds light an earth fault so check all the earth connections on all units.
Thank you for pointing me in the right direction. There was a short in the ground wire in the connector to the tail light. I removed the connector and re wired the light. This solved the problem
