Old 12-06-2009, 06:45 PM
Default Power steering fluid leak and now cut belt ...
Hi,
I had a leaking power steering system (I am not sure where the leak is coming from) so I cut my belt not thinking that anything vital would be hooked up to it. Apparently I was wrong. The water pump and AC are also attached on the same belt (yes?) and my car overheated within a few minutes. It's pretty cold up here right now (north of Toronto) so I've only driven short distances a couple times.
Does anyone have any suggestions? How do I find my power steering leak? I guess I am going to have to get a new belt. What can I use for power steering fluid once I get the belt on? (it will just be getting blasted all over my driveway and road until I find the leak)
Thanks,
(1997 Jetta turbodiesel)
Old 12-06-2009, 07:27 PM
Car: 1999 jetta
In general, it's pretty common for the high pressure hose to leak Check the hose clamps too. Use VW PS fluid since it's some special hydraulic fluid and is good for the seals.
Old 12-06-2009, 08:16 PM
Car: 1998 Jetta TDI diesel
Mods: none
There are dyes you can buy but it's probably the hose, a bolt at the pump, or a hose clamp.
Use 11S synthetic fluid: http://www.blauparts.com/vw/vw_fluid...rsteeringfluid, the pentosin stuff is the same as the genuine VW stuff. Don't use ATF or brake fluid in the PS steering system.
Old 12-06-2009, 09:34 PM
All the belts are important. Yes, the v-belt has the AC and water pump on it. Thankfully you didn't cut the serpentine belt which drives the oil pump and alternator! The leak should be obvious. It's possible the reservoir has cracked. Fill it up to min when cold, with the engine warm it should be filled to max.
Old 12-06-2009, 09:40 PM
Is there a belt that I can use just for the AC - water pump and exclude the power steering pump? If the power steering leak is something serious I don't know how serious I am about fixing it is all.
Old 12-06-2009, 09:42 PM
Is a cracked reservoir serious? I don't know if I will be able to find this dang leak.
Old 12-06-2009, 10:00 PM
It doesn't look like there is a leak at the actual pump, and the leak was coming from a more central area (a little more central than the oil pan) last night. Where does the pump pump to? There's a mess of liquid all over the inside area (no idea of parts etc.) and I don't know how much is boiled-over coolant from the heating up.
Old 12-06-2009, 10:33 PM
Also, the slider/bolt that the power steering pump is on is more than difficult to move. Any suggestions?
Old 12-07-2009, 12:22 AM
See this article for suggestions on moving the slider bolt;
http://www.myturbodiesel.com/1000q_h...assatchrip.htm
The PS fluid is a closed circuit from the reservoir to the pump and to the steering rack. There should be some banjo bolts (bolts with a hole in the middle to let fluid pass) at the pump and the steering rack. It's unlikely but these could have loosened. More likely is the high pressure hose is leaking. You just have to follow the line.
I don't know of a belt you could use to exclude the PS pump since the OEM belts are: with AC or without AC. No option for no power steering. You could have a custom belt made but I would really just try to fix the leak. Here is a diagram of the system:
Old 12-07-2009, 11:00 AM
Okay, thanks I will see what happens.
