I have a problem with my rear brake balance. The left rear wheel has less stopping power than the right rear wheel (I had the car tested and left rear wheel had 1.0KN of stopping power when the right rear wheel had 1.4KN which means a 40% difference). The front brakes are correctly balanced. All the brakes release correctly after using brakes and the hand brake is also correctly balanced. As such, I believe that the problem is caused by brake fluid pressure applied to rear brakes. Car details: Golf mk3 1996 1.9L TDI 81 kW with VNT turbo ABS brakes with drums in the rear (ABS system seems to be working ok and will activate under heavy braking) Some questions:
Yes. It's probably seized or the caliper is sticking. It's on the rear axle and has a lever. When the car shifts it changes the proportioning. You need a brake specialist to test and adjust it because the pressures are too high. Did you fail inspection?
Currently, the balance between front and rear is correct but the balance between rear right and rear left are not correct. I'm trying to figure out where the problem is. Yeah, I failed yearly inspection because of this issue. The legal limit for rear balance difference is 30% and I got 40%. The difference in balance has been within 5% during previous years, so something has changed during the last year. Within last year, I have replaced right front brake caliber but I wouldn't expect that to change the left rear braking force. |
I would replace the caliper. It sounds like it's sticking. The proportioning valve is front-rear. The only way I can think of testing it other than by measuring braking force as you've already done, is to remove it and inspect it. If you do that, you might as well rebuild it but it's probably cheaper to buy a rebuilt caliper. As long as it's a good rebuild, it should work. It's possible the metal brake line got crimped. I don't know if they use separate lines for left and right on this year with ABS. I know later models with ABS do but their proportioning valve is at the ABS pump. I don't think changing the fluid will do anything unless there was a massive air bubble in there.
I think I'll proceed to replace the caliper. It's not sticking very much because the brake releases okay (and there's still some stopping power), but I think that you're right that the problem must be there. |
Thank you. |
good to hear.
