Old 07-06-2009, 05:01 PM
Default engine light on
Hi, I need some help finding out what is wrong with my 98 jetta tdi. The engine is not pushing as it used to, so I hooked up the computer to the car and I got these fault codes: 00575, 00750 and 65535, if eneyone could help me it would be greatly apreciated. Thanks
Old 07-06-2009, 05:33 PM
00575 is intake manifold pressure intermittent. This means there is a problem with a vac hose, vac hose inside the ECU, bad/rusty wastegate, sensor, or there's a boost leak.
See these:
http://myturbodiesel.com/1000q_how_t...cuhosechip.htm
first link on the how to list because every mk3 TDI will have this problem
http://myturbodiesel.com/1000q_how_t...boostleaks.htm
constant low power
http://myturbodiesel.com/1000q_how_t...owpowerfix.htm
00750 is warning lamp code
65535 - Internal Control Module Memory Error is almost certainly the short hose inside the ECU. In fact, that's the classic symptom of a leaking ECU hose. First fix that hose since it's connected to the boost system and I'll bet the other codes may also be fixed. If not, go from there.
Old 07-07-2009, 02:11 AM
Car: honda civic
2nd, the hose fails. It's a bad design on VW's part. It's easy to remove and I think it connects to a sensor. Bad hose = bad sensor readings.
Old 07-07-2009, 09:03 AM
the hose inside the edu did have a leak, I replaced it and erased the faults.. now I´m waiting to see if the engine light comes back on. Thanks for the Help
Old 07-19-2009, 05:07 PM
Smile increase horsepower
My car did not have power like it used to só I cleaned out the intake manifold it was claged up. Now I got my power back. What I like to know now is where I can order the chips for the ecu to increase horse power.
Old 07-19-2009, 06:07 PM
Thumbs up
Try rocketchip, kermatdi, or alligator. There's links to chip tuners in the basic performance FAQ: http://www.myturbodiesel.com/1000q/basicpowermods.htm
Old 12-20-2011, 03:20 PM
Rig Rig is offline
See these:
constant low power
I got these codes, and I replaced the vac lines and the vac tube inside the ECE. The fault codes went away, except for the 00750.
What warning light is that 00750 referring to?
Old 12-20-2011, 09:22 PM
This is an old thread you have brought up?
VAG Error Code: 00575
Fault Location:
Intake manifold pressure
Possible Cause:
Intake leak/blockage.
Mass air flow (MAF) sensor (G70).
Manifold absolute pressure (MAP) sensor (G71).
Turbocharger (TC) wastegate actuator/regulating valve.
Hoses interchanged/not connected.
Wiring.
VAG Error Code: 00750
Fault Location:
Malfunction indicator lamp (MIL) - circuit malfunction
Possible Cause:
Engine control module (ECM) incorrectly coded.
Wiring.
Malfunction indicator lamp (MIL).
VAG Error Code: 65535
Fault Location:
Engine control module (ECM) - defective
Possible Cause:
Engine control module (ECM).
Old 12-22-2011, 10:32 PM
Rig Rig is offline
Old thread, same code!
I'm pretty sure this is the engine malfunction light, since I haven't seen the CEL in a very long time, maybe never.
Are all those bulbs clear?
