Old 11-02-2011, 10:11 AM
Car: VW Golf MK3 R reg 5 door
Default Dreaded Limp Mode
Hi,
I've been reading around on here trying to find a solution for my 'limp mode' problem, there is some good advice, it seems to me that there could be a pressure issue causing the limp mode to kick in, is this the kind of thing that i can attempt to fix myself with only basic tools or best left to a mechanic?
Old 11-02-2011, 11:40 AM
Well its no use guessing you obviously need an Autoscan of someone with VAG-COM\VCDS then you will have a list of error codes you can sift through.
Oh and don't let that cowboy that rewired your radio do it?
Oh I wouldn't use Location: TQ9 UK you may as well put Torquay, UK?
Old 11-04-2011, 08:23 AM
Default Fixed It
Got a mechanic, plugged it into the machine, got an error code, turns out a vacuum line into the ECU was dislodged , reattached it, works fine.
Would never have done it without this website - http://www.myturbodiesel.com/1000q/m...de-TDI-fix.htm
forgotton what a difference it makes having turbo on the motorway, thanks a lot.
J
