Old 08-07-2010, 12:32 AM
Car: 1981 Jetta 1.6D
Mods: TDI on the way
Default A/c question
I see veedubyoo just posted an A/c question, but this is completely different, and I didn't want my first post to be a thread jacking!
Ok So car is brand new to me, no idea on anything about it (sadly). Had it running in the driveway today as I was farting around with it, and i thought to myself "Hey lets turn on the A/c, for the hell of it and see what happens" Well doesn't it start blowing ICE COLD.. WOW. so i had the air on for maybe 5-9 minutes, could hear the clutch on the compressor going on and off, and could see the rad fan spinning away. Turn the air switch off and shut the car down for about 10 minutes when my brother arrived to have a chat. Start the car back up to show him the ice cold air on the new to us car, and there was nothing just ambient temp air. The light on the switch was on, and the recirculation button worked I think.. where it would start sucking air from the car instead of outside air.. but the A/c compressor did not kick on and the rad fan did not come on either. So I believe it to be an electrical problem.. maybe the switch just went on me?
Whats my direction of attack on this boys? thanks a bunch in advanced.
Jeremy
Old 08-09-2010, 10:44 AM
So same thing tonight fella's...
start the car up pull it out and get it up on ramps, take a look underneath and get the front end all back together (fenders, hood, bumper, front upper cross member, lights).
and after i was done, about 2.5-3hrs.. start the car up and for ****s and giggels I turned the air on to see what would happen. Hear the compressor kick on and ICE cold air starts blowing out.. turn it off and the heat on to see how it does and how the rear defrost does (defrost works ) and then i try the air again.. hitting the ac switch does not turn on the A/c... the light comes on but no compressor or rad fan comes on.. I dont get it
Old 08-09-2010, 11:56 AM
It's not the AC fuse. Charge? Pressure valve? It should switch the fans on high. Do you have a bentley manual? It says to test the pressure switch, jump terminal 1 and 2 on its plug. The AC clutch should turn on. In this case either the AC is discharged or the switch is bad.
Old 08-11-2010, 11:50 AM
I do not own a bentley, might be something on the shopping list :P
So where exactly is this switch located? for me to be able to jumper pins 1 and 2. If the clutch turns on we have concluded what exactly? The system is depressurized? or The switch is bad. Whats the cheaper fix? A DIY recharge from Canadian Tire? Lol
Where is the switch?
Old 08-11-2010, 03:07 PM
It should be right next to the drier on the right hand side. It turns the clutch turns on, the pressure switch will turn it off it the pressure gets too high or low. The inspection glass should also let you see if it has a charge.
Old 08-11-2010, 03:43 PM
sorry to be such a noob, but I have never had any expereince with A/c systems, or this car lol. Where is the drier inside or outside of the car?
I know what a site hole is, what is it that I should be looking for in it though? and where is it located as well?
thanks a TON!
Old 08-11-2010, 06:15 PM
The drier is inside the car and looks like a silver can. I think it's a kind of filter that removes moisture from the AC system. Not an AC guy. There's a high pressure line which carries the freon after being compressed where it goes to the condenser and releases heat. Then it goes to the evaporator and absorbs heat from the cabin and goes back to the compressor.
If your car doesn't have a site glass, you have to have it tested for leaks. I had this done once - they vacuum extract the old coolant and put in a dye to detect the leak location. Both are on the low pressure side.
