Old 10-09-2011, 01:39 AM
Car: 1997 Passat TDI 1Z
Default 5th gear went out
was driving down the highway and 5th gear just popped loose, and all i heard was a whirring noise coming from the tranny, no go.
1st - 4th worked fine, so i limped home.
Popped the cover off the end of the tranny, and everything looked whole. I engaged 5th gear, grabbed the brake disc and jerked. The bolt holding the small gear onto the shaft spun, but the small gear did not spin.
I do not have the T60 socket nor the gear puller to progress with this at the moment, but what are the odds that its the splines on the small gear that have stripped and not the splines on the shaft that have worn off?
Old 10-09-2011, 05:38 AM
Car: 2000 NB
Mods: ventectomy
good (I hope)
Is the 5th gear the stock factory installed?
Some have changed the gear for less RPM while engaged.
Old 10-09-2011, 05:07 PM
I'm pretty sure the gears are stock. I've only had it a couple of months, though. RPMs are a bit too high at highway speeds to have been upgraded.
Old 10-09-2011, 06:50 PM
Car: 2000 NB
Mods: ventectomy
please keep us posted.
Old 10-14-2011, 02:23 AM
It is not looking good at all.
I managed to remove the gear tonight. Splines on the gear look alright:
Which leads to a look up beneath:
Splines on the shaft are TOAST.
Looks like I'll be shopping for either a new transmission, or a Samurai for a TDI swap - whichever comes cheaper.
1997 Passat TDI - 248k
2005 Passat TDI (sold)
1996 Passat TDI (RIP)
Old 11-18-2011, 11:07 AM
Car: Mk III Jetta
You Sir ran the tranny low in oil
I would also inspect the 5th gear needle bearing for damage
You should be able to pick up a used input shaft, for cheap, on the net ( Vortex should be your best bet)
