Old 11-10-2010, 03:35 PM
Car: 1998 VW Jetta TDI
Default 1998 VW Jetta TDI Low Power
My 1998 VW Jetta TDI has 214,000 miles on it. Gradually it started to produce heavier and heavier black smoke. I had the intake manifold removed and it was full of oily carbonized soot. After cleaning the car quit smoking and mileage improved. However the engine hesitates and smokes a little more with the MAF sensor plugged in. Unplugging the MAF sensor allows the car to run clean with no hesitation. However with or without the MAF the car has minimal power. Generally it is still fine for around town but acceleration on the freeway is slower than it should be. I can still drive at 70 or 80 just fine. Haven't tried any faster. I replaced the MAF, but no change in behavior, so I have left the sensor unplugged. Air filter is fine.
I'm thinking wastegate valve, EGR valve, or turbo charger could need cleaning or replacement.
This car has always been a good running vehicle with great fuel mileage. Any thoughts or other ideas.
Old 11-10-2010, 06:05 PM
Fuel filter? http://www.myturbodiesel.com/1000q/a...-1996-1997.htm
Boost leak? http://www.myturbodiesel.com/1000q/m...-DIY-check.htm
Check the fuel injection quantity http://www.myturbodiesel.com/1000q/m...er-mod-TDI.htm and injector balance. It's also possible the injectors are dirty and not working well.
Also, post moved to mk3 section since it has some technical questions.
Old 11-10-2010, 09:41 PM
Car: 96,2 97Passats,98,2000 Jettas,3 81 Rabbit pickups, 95 Chevy pickup diesel
Could also be the pressure hoses that go to the N75 valve and also to the ECM
Old 11-12-2010, 12:14 PM
Car: 1998 jetta TDI
Default cleaned intake tdi
First post here andd happy to be a member. We cleaned our 1i
intake at 145,000 and were rewarded with the ability to climb hills again in gears higher than 2nd.
amazing the government re-burn requirments are so expensive to purchase and maintain with questional results. Thanks to all who contribuite to the forms.
