how can you tell which engine it is? is it part of the vin or stamped anywhere? can oil pumps be in spec but make gear clatter noise? i have, what sounds to be valve clatter from the top end because of lack on oil. i am going to install an oil pressure gauge at the top of the filter housing to see what its putting out. i have also heard of over heated oil coking to hydraulic lifters stopping theyre ability to compensate for lash. any other suggestions? thanks justin |
It's a 1Z.
There should be a sticker on the timing belt cover with 1Z somewhere on it but it can fall off. If your injection pump looks smooth like this it's definltely a 1z: ![]() Some jetta also had 1z but the rest had AHU. The AHU had ribs on the injection pump which made it look different from the above pump. |
The vin can tell you some equipment information but I don't think it has the engine code. Passats are definitely 1Z engines.
