Old 08-30-2010, 09:55 AM
Default 1994 mk3 jetta/vento central locking
I have a problem with my central locking system/ alarm. When I try to lock my doors from the driver's side it only locks the drivers door. But if I try to open it then it opens all the doors. Same problem goes with my passanger door.
There is also a problem locking/unlocking doors remotly. It never works on the first time i click, usually it works on the third try. Its like the vacuum pump gets the signal because it makes a short noise and the lights also blink but thats it. Im using WAECO MT150.
I alredy checked the vacuum hoses and I didnt spot any leaks.
Sorry for my grammer and I hope someone can help me with my problem.
Old 08-30-2010, 12:28 PM
Did you check the vacuum hoses in the door wiring boot? Did you check the wiring to make sure it hasn't cracked? There should be a rubber boot in the door hinge. Slide it back and carefully inspect all the wiring.
Have a helper press the remote while you look at the vacuum pump. Maybe it's bad and can only go one way.
Old 08-30-2010, 11:22 PM
Car: none
Mods: Wyo
Is a WAECO MT150 an aftermarket remote?
Old 08-31-2010, 03:29 PM
The wiring and the hoses seemed okay in the door wiring boot's.
Also yes the WAECO MT150 should be an aftrermarket remote but i don't think that the problem is with it because the vacuum pump gets the signal when i click on the remote.
Old 09-02-2010, 02:12 PM
Car: none
Mods: Wyo
Chitty, do you know how to check the vacuum pump?
Old 09-20-2010, 07:38 PM
Car: 1996 Jetta TD
Default central locking
I would imagine that checking all the plastic lines for leaks could be tough to do visually. Perhaps if you have a Mity Vac you could tap into the lines and see if you can a) make the locks work and b) see if the vacuum holds. I would think you could also put a vacuum gage on the pump, unfortunately I don't have the specs for this.
I recently repaired my own car and discovered that a line had let go at one of the connectors inside the door jamb area. The other observation that I made was that the pump would run for 10-20 seconds when activated. I'd be a bit concerned if you pump only come on for a second or two.
