Old 09-23-2011, 11:38 PM
Default Rain sensing wipers on VW Passat need activation w/vag-com VCDS to use rain sensor
Well, another mystery of VW parts is solved. The ad brochures for the 2012+ VW Passat say it has intermittent wipers, however, some people say it does not have rain sensing wipers. The rain sensor is clearly visible, it's the thing the rear view mirror is attached to. The sensor is also used for automatic headlights which is enabled from the factory. As it turns out, the rain sensing function of the sensor is probably disabled from the factory. If you don't want it, you're all set. If it's enabled and you want it, leave it alone. If it's not enabled and you want it, below is the procedure.
Use your VCDS tool, go to CECM (central electric) module, enter long coding for the RLS (rain-light sensor), and unclick the checkbox for "Rain sensor inactive". Save and exit. It will now be active.
Here is how to do it: http://www.myturbodiesel.com/1000q/b...activation.htm
Last edited by chittychittybangbang; 10-18-2011 at 10:06 PM. Reason: finished article and added video
Old 09-25-2011, 02:13 AM
Car: Jetta TDI 2006.5
Well done, Sir... will be on my short list of immediate mods.
Old 09-27-2011, 12:22 PM
Car: 2012 Passat SEL TDI, 2013 Ford C-Max SEL Hybrid
Mods: Conti PureContact
Thanks, I will look into this when my Passat arrives.
Old 10-18-2011, 10:05 PM
.......and it's done. I have updated the first post with the details on how to do this. I am still putting together a DIY list for the NA Passat, will update when done.
Old 10-19-2011, 05:03 AM
Car: 2012 Passat SE TDI DSG
Mods: 35% tint so far
I did mine yesterday and it definitely works. Thanks for the info. Now if we can get the windows via remote up and down I will be stoked.
Old 10-19-2011, 12:48 PM
I tried to do the comfort remote but couldnt' get it to work. The checkbox is there but it does nothing. Perhaps this might change in the future with different control modules or software updates but for now, it doesn't work. To make all windows go up-down, you can hold the driver's window button with the door open.
Old 10-19-2011, 01:51 PM
I also heard talk of the rain sensor having the ability to auto-close windows/sunroof. Anyone test this yet?
Old 10-19-2011, 05:33 PM
Car: 2012 Passat TDI SEL
Yes, chittychittybangbang did my car and it does work. I am sure he will chime in with the details
Old 10-19-2011, 05:53 PM
I tried as well but mine doesn't work either. I sent my auto scan to Ross Tech with hopes that they might be able to figure it out soon.
Old 10-19-2011, 06:24 PM
Yes, I just finished the video and the writeup, Rain auto close feature on VW Passat TDI SEL with VCDS mod (vag-com trick) see this post for any questions and support on that article.
Nice meeting you TDICT, if you happen to leave the windows open for more than a day, please let me know if the windows close by themselves. I am interested to know if this is also the case on the Passat. It should but you never know!
