Old 01-23-2012, 11:42 PM
Car: 2012 Passat Tdi comfortline
Default Coolant Smell
So after driving my 2012 Passat TDI and parking it in a garage I can smell a bit of engine coolant. When I check level when hot it seems to be ok and it does not change. Had a dealer look at it and they said that everything is ok and they can't find any issues. Smell seems to be stronger on the drivers side of the engine. Does anyone of you smell coolant and should I be worried about it?
thanks.
Old 01-24-2012, 09:38 AM
Car: 2011 Jetta TDI
Mods: 2011 Jetta-none, 2008 RAM Mega Cab lost the BlueTech emissions
Hi,
Is the smell similar to a water vapor smell? Do you smell this all of the time or just once in awhile?
What you might be smelling is the completion of the Regen cycle. I also use to smell the Regen finishing up on my 08 Ram but the truck lost the Blue-Tec emissions somewhere. Now my wife's Jetta has the same orders when regening.
Jim W.
11 Jetta TDI DSG Auto with Nava system, -Wife's
08 2500HD Mega Cab SLT, 6.7L CTD 68RFE,Optix Gauges Pyro,Boost,Trans Temp A Piller mount, Mag-Hytec Trans Pan, Front & Rear Diff Cover, Smarty, MBRP 5" Exhaust, Silver, Westin Side Steps, Line-X Spray in Bed Liner over the rails, Bed Cover, Prodigy BC, 15K Reese hitch and pulling a 11K 5er-My ride
Old 01-24-2012, 01:34 PM
Originally Posted by Jim W View Post
Hi,
Jim W.
It smells when it gets hot and after each ride. dealer told me it could be vapours due to engine running hot. Smell is on the right side of the engine, and when I smell around overflow tank, there is no smell.
Old 01-24-2012, 01:49 PM
Car: Jetta TDI 2006.5
Sounds like you have a valid issue, but dealer will not be of much help until there are visible signs. My recommendation is to remove the belly (bottom engine cover) to take a close look and be prepared to snap some photos. Definitely do this before your warranty expires.
