Go Back   VW TDI forum and Audi TDI forum - myturbodiesel.com > myturbodiesel.com forums > General Diesel Discussion > Ross Tech VCDS forum
Old 02-27-2012, 01:10 PM
bschurman's Avatar
Car: 2012 JSW
Default VCDS disable blutooth audio?
Hi,
I would like to disable my bluetooth audio permanently in my 2012 JSW and I found this.
"You can disable BT audio via VCDS. Go to the 77-Telephone module and to Byte 4. Check the box and BT Audio is disabled."
Would someone have any better information/screen shots on this as I am a VCDS neophyte and I don't want to mess anything up?
Any help is greatly appreciated.
Thanks,
->Ben
Old 02-27-2012, 02:17 PM
Thats one are area I haven't bothered with so this is the only picture 77 - Telephone button on Electronics 1 tab.
You can add your own pictures in your own Album if you look in your profile thats where mine come from.
Your thread has been moved to Ross Tech VCDS Section.
Old 03-05-2012, 09:15 AM
bschurman's Avatar
Car: 2012 JSW
Thank you for the info. Also, thank you for the move. I should have noticed the specific section for VCDS.
I was able to get this working perfectly. Now I no longer have the problem with the BT Audio taking over if I leave the phone plugged into the MDI when I shut off the car. I also no longer need to wait for the BT to pair before I plug the MDI in in the morning.
Below are the the screen caps from my session.
Click on the 4th byte
Old 03-05-2012, 04:54 PM
Thanks adding to FAQ!
