Go Back   VW TDI forum and Audi TDI forum - myturbodiesel.com > myturbodiesel.com forums > General Diesel Discussion > Ross Tech VCDS forum
Old 10-01-2011, 02:56 PM
Default RNS 315 coding issue or antenna issue?
I installed an RNS315 the other day, worked fine during testing. The next day, its location is about 600 miles off in Canada. Then the location was jumping around. Any ideas? Could it be an antenna problem?
Here is the coding of the RNS-315. The compass module was unplugged and position sensing was turned off in the CAN BUS with navigation turned on.
This is on a 2012 Golf 2.5 with CAN BUS# 7n0 907 530 h. Attached is a screenshot of the rns315 coding.
Old 10-01-2011, 03:16 PM
Does an Autoscan show any errors Chitty?
Old 10-01-2011, 09:47 PM
Car: 2012 Golf 2.5
Hey Chitty, I will be purchasing a new antenna for the unit to rule out that out as an issue. I'll keep you posted once the new antenna arrives.
Old 10-02-2011, 12:22 PM
No errors, a battery reset didn't do anything, I am still waiting on the results of this.
Old 10-03-2011, 01:21 PM
I don't know if VAG-COM\VCDS shows any Measuring Blocks for the Navigation on signal strength but you could try a driving test if it does.
Old 10-05-2011, 05:59 PM
Car: 2012 Golf 2.5
just got the new antenna(s) in about to slap them on and see if that fixes the issue. I'll update with my findings.
Old 10-06-2011, 10:05 PM
Car: 02 Gti, 10 Gti
I can't see the SW level but the NAR vehicles have a TSB 91-10-33 (2024776) Radio, Navigation RNS 315, Updated Programming for System Reset
"Software problem in RNS 315 causes unit to reset if the vehicle position is west of 128° longitude. The problem only occurs in Alaska, Hawaii and the Canadian provinces of British Columbia and Yukon."
I haven't spoke to anyone that actually had a problem, but I wouldn't be surprised if "system reset" wasn't the only correction that update resolved. Post the scan if this isn't fixed.
Old 10-07-2011, 12:32 AM
Would position sensing being turned on make any difference? From what I hear, some people leave it on and the NAV works fine. Was there a difference in year?
Old 10-08-2011, 09:56 AM
Car: 02 Gti, 10 Gti
A lot of people report conflicts when the 1C-Position Sensing / Compass module is plugged in with the RNS-510 retrofits but I never unplugged mine. The only functional concern I have is when the car is stopped and on a specific dash/MFA screen, the small icon compass display switches on and off with a mild flickering every few seconds. The normal (large) Navi compass screen that is shown when you do not have a destination entered with active navigation directions is fine.
Hopefully someone with the 315 will leave comments on that issue. It wouldn't hurt to unplug is and remove the 1C module from the installation list in the Gateway.
Old 10-08-2011, 02:57 PM
Car: 2012 Golf 2.5
Here a screen shot of the gps location information, signal strength and gps status. The screen show shows that its clearly not getting the signal.....
and also down below show a full scan of my car. Ignore the abs malfunction (disconnected battery) along with the TPS sensors (leaky value stem) and truck light (led bulb);
Chassis Type: 7N0
Scan: 01 02 03 08 09 15 16 17 19 1C 25 37 42 44 46 52 56 77
VIN: WVWBB7AJXCW030157
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1C-Position Sensing -- Status: Cannot be reached 1100
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CBU) Labels: 07K-906-055-CBT.clb
Part No SW: 07K 906 055 CL HW: 07K 907 309 B
Component: 2,5l R5/4V G01 1158
Revision: T4H04--- Serial number:
Coding: 0000075
Shop #: WSC 01357 011 00200
VCID: 7AF0376E4BC5
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09G-927-750.lbl
Part No SW: 09G 927 750 LM HW: 09G 927 750 MK
Component: AQ 250 6F 1919
Revision: 00H90000 Serial number:
Coding: 0000840
VCID: 8716DE9A8837
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 114B400C492500FA880C02E992200041B70000
VCID: 7BFE326A44FF
2 Faults Found:
02214 - Tire Pressure Warning
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 3
Reset counter: 128
Mileage: 2029 km
Time Indication: 0
Date: 2002.14.27
Time: 16:11:51
Freeze Frame:
Count: 0
Count: 32768
Count: 4608
Count: 16401
Count: 50433
Count: 1
Count: 1026
Count: 0
01325 - Control Module for Tire Pressure Monitoring (J502)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 139
Mileage: 2421 km
Time Indication: 0
Date: 2003.14.03
Time: 00:01:41
Freeze Frame:
Count: 2
Count: 12
Count: 12800
Count: 16390
Count: 51200
Count: 0
Count: 65281
Count: 0
Address 08: Auto HVAC (J301) Labels: None
Part No SW: 7N0 907 426 AN HW: 7N0 907 426 AN
Component: AC Manuell H19 0304
Revision: 00001015
Coding: 0000001002
ASAM Dataset: EV_ACManueBHBVW36X A01010
ROD: EV_ACManueBHBVW36X_VW36.rod
VCID: 8004C586AD19
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 084 G HW: 1K0 937 084 G
Component: BCM PQ35 B 110 0651
Revision: 00110 AC
Coding: 69180A3A90272A04008800C1500004044A010386424D8D6064 8020200040
VCID: 3260DF4ED335
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 03061 26 0512
Coding: 009795
1 Fault Found:
01565 - Luggage Compartment Light (W3)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 4
Fault Frequency: 28
Reset counter: 145
Mileage: 2103 km
Time Indication: 0
Date: 2002.14.30
Time: 18:17:40
Freeze Frame:
Term 15 Off
Voltage: 12.30 V
OFF
ON
Term 50 Off
OFF
OFF
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5K0 959 655 H HW: 5K0 959 655 H
Component: AirbagVW10G 013 0724
Serial number: 003GVRA0757K
Coding: 00003131
ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
ROD: EV_AirbaVW10SMEVW360_VW36.rod
VCID: 3F86867A1067
Seat occupied recognition:
Subsystem 1 - Part No SW: 5K0 959 339 HW: 5K0 959 339 SW
Component: BF-Gewichtss. 007 0002
Serial number: ---0000R--0005H7U200
Driver's Airbag Crash Sensor:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354 SW
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME2D64725FZZZ4
Passenger Side Airbag Crash Sensor:
Subsystem 3 - Part No SW: 5K0 959 354 HW: 5K0 959 354 SW
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME4F02735FZZZ2
Driver's Rear Airbag Crash Sensor:
Component: S.Sens.Fahr.H --- ----
Serial number: 3512QSME48190B38ZZZZ
Passenger's Rear Airbag Crash Sensor:
Component: S.Sens.Beif.H --- ----
Serial number: 3522QSME7E390B39ZZZ5
Driver's Front Airbag Crash Sensor:
Component: F.Sens.Fahr --- ----
Serial number: 35527SME31497027ZZZ9
Passenger's Front Airbag Crash Sensor:
Component: F.Sens.Beif --- ----
Serial number: 35627SME49736F27ZZZU
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 507 AE HW: 5K0 953 549
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90422KFA00127
Coding: 5880140000
ASAM Dataset: EV_SMLSNGKUDS A05001
VCID: 73EE1A4A6CAF
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 5K0 920 972 B HW: 5K0 920 972 B
Component: KOMBI H03 0607
Serial number: 00000000000000
Coding: 270F01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
VCID: 2F66D63AC007
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 H HW: 1K0 907 951
Component: J533 Gateway H42 1620
Revision: H42 Serial number: 160611F2002662
Coding: 350000
VCID: 356AE452225B
1 Fault Found:
00484 - Vehicle Position Recognition Control Module (J603)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 106
Mileage: 2696 km
Time Indication: 0
Date: 2003.14.04
Time: 16:29:07
Address 1C: Position Sensing
Cannot be reached
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 0607
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
VCID: EAD0872EBB65
Address 37: Navigation (J794) Labels: 1K0-035-27x-37.clb
Part No SW: 1K0 035 274 HW: 1K0 035 274
Component: RNS315-NAR H05 0011
Serial number: VWZAZ2K8422986
Coding: 040004210400000000001000
ASAM Dataset: EV_RNS315VWNARV1UDS A01005
ROD: EV_RNS315VWNARV1UDS_VW36.rod
VCID: E1C2E0024653
2 Faults Found:
1048667 - Antenna for Satelite Radio
B10F4 13 [009] - Reserved by ISO 15031-6:2005
Freeze Frame:
Fault Status: 00000001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 106
Mileage: 2696 km
Date: 2003.14.04
Time: 16:31:48
1048669 - Tuner for Satelite Radio
B11CF 53 [009] - Reserved by ISO 15031-6:2005
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 106
Mileage: 2696 km
Date: 2003.14.04
Time: 16:31:48
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
Component: Tuer-SG 009 2117
Coding: 0001076
VCID: 3162D042D633
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 69 3201
Revision: 00H20000
VCID: 346CD9562921
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
Coding: 0001076
VCID: 3260DF4ED335
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 F HW: 7P6 035 730 F
Component: TELEFON H09 2730
Revision: 1B001001 Serial number: 00007660251840
Coding: 0A00000000010100
ASAM Dataset: EV_UHVNA A01015
ROD: EV_UHVNA_VW36.rod
VCID: 356AE452225B
End ---------------------------------------------------------------------
