Go Back   VW TDI forum and Audi TDI forum - myturbodiesel.com > myturbodiesel.com forums > General Diesel Discussion > Ross Tech VCDS forum
Old 06-30-2012, 04:07 PM
Car: Audi A5 / 2010
Default Bluetooth Phone Kit Coding Problems VCDS
My first post, please be gentle.
My car: Audi A5 (2010)
Aftermarket kit purchased: Viseeo Talk2Can AMI
Problem encountered: "Telephone Not Available" message on control unit
I can connect my iPhone to the Viseeo kit successfully but can't use the telephone function in the car
Coding instructions provided by Viseeo:
A.With Sound System(Control Address 47)
Setp1 :
Gateway 19 Installation List ---
2E - Tick Media Play3
47 - Tick Sound System
77 - Tick Telephone
Enter 19 - CAN Gateway Coding - 07 : Codung value - 000303
Step2 :
Radio 56 Coding - 07 : enter Long Coding Helper ---
Byte 1 : 02(Sound System Correction : Standard Sound System(Audi Sound)
Byte 2 : 00(Speaker Channels:Sound System(No Speaker Monitoring))
Byte 3 : 82(Bit7 : Long Wave Band blocked,Bit1:Telephone CAN-connection
Monitoring)
Byte 4 : 01(Treble Speaker Monitoring:Not Active)
Byte 6 : Tick Bit 7 (Telephone control via voice control active)
Tick Bit 2
Byte 11 : Tick Bit 3(Mobile Device Interface(MDI) Setting active)
Step3 :
Sound System 47 Coding - 07 : Codung value - 0203010102
I have coded the car using the above instructions and encounter the following using VCDS:
Thursday,28,June,2012,12:50:26:53489
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 8T0
Scan: 01 03 05 08 09 10 15 16 17 19 42 46 47 52 53 55 56 62 72 77
VIN: WAUZZZ8T2BA031955 Mileage: 43010km/26725miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Cannot be reached 1100
Address 01: Engine (J623-CAHA) Labels: 03L-906-019-CAG.clb
Part No SW: 03L 906 022 NP HW: 03L 906 019 AL
Component: R4 2,0L EDC H29 9098
Revision: 25H29---
Coding: 1A194012232503080000
Shop #: WSC 00681 210 91360
ASAM Dataset: EV_ECM20TDI03L906022NP A02009
ROD: EV_ECM20TDI03L906022NP.rod
VCID: 800543D21B18A29
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 BF HW: 8K0 907 379 BF
Component: ESP8 front H04 0030
Revision: -------- Serial number: --------------
Coding: 160504
Shop #: WSC 06325 000 00000
VCID: 7EF9BD2AE9EC549
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 CP HW: 8K0 907 064 CP
Component: BCM2 2.0 H04 0430
Revision: 00002001
Coding: 033400
VCID: 800543D21318A29
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H50 0071
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T2 820 043 AE HW: 8T2 820 043 AE
Component: KLIMA 1 ZONE H08 0180
Revision: B1000000 Serial number: 01300920101969
Coding: 34240000
VCID: 75EBA206DCDA171
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H30 0392
Revision: 10030001 Serial number: 00000000670732
Coding: 260050914034AF000009000300005D5D0F1D03080601010100 0000
VCID: 3C7D7722BF70869
Subsystem 1 - Part No SW: 8T2 955 119 D HW: 8J2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 200910 H12 0070
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Coding: 02532C
Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Component: E1 - LDS H08 0090
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 R HW: 8K0 919 475 A
Component: PARKHILFE 8K H06 0070
Revision: 11001001 Serial number: 50941027910275
Coding: 10020F
VCID: 48951BF2FBA8DA9
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 J HW: 8K0 959 655 J
Component: AirbagVW-AU10 H41 0610
Serial number: 003GKD0L02XM
Coding: 30363438363030303030554A305238543053
ASAM Dataset: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 448D0FC2CF80FE9
Crash sensor for side airbag; driver side:
Serial number: 6334MSME5803263BB
Crash sensor for side airbag; passenger side:
Serial number: 6344MSME58732D14H
Crash sensor for side airbag; rear driver side:
Serial number: 6352QSME46750726E
Crash sensor for side airbag; rear passenger side:
Serial number: 6362QSME3F702122A
Crash sensor for front airbag; driver side:
Serial number: 63732SME5170323CW
Crash sensor for front airbag; passenger side:
Serial number: 63832SME2B703F00
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8R0 953 568 K HW: 8R0 953 568 K
Component: Lenks.Modul H06 0156
Revision: 00000000 Serial number: 20101006000003
Coding: 000016
VCID: 49931EF6E0A2231
Component: E221 - MFL H04 0010
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8T0 920 983 B HW: 8T0 920 983 B
Component: KOMBIINSTR. H40 0258
Revision: 00100000 Serial number: EHY75K0AA
Coding: 2F05300002002600010000
VCID: 3D7B7A26A46A8F1
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 AB HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0117
Revision: GB800053 Serial number: 5300G1091583DF
Coding: 00CF07
VCID: 810346D61812AB1
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0140
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H17 0042
3 Faults Found:
01303 - Telephone Transceiver (R36)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 216
Mileage: 42841 km
Time Indication: 0
Date: 2012.06.22
Time: 20:13:20
Freeze Frame:
Bin. Bits: 10000
Voltage: 12.10 V
Count: 12
Bin. Bits: 10000
02256 - Quiescent Current
001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01100001
Fault Priority: 7
Fault Frequency: 8
Reset counter: 231
Mileage: 42870 km
Time Indication: 0
Date: 2012.06.22
Time: 22:44:00
03041 - Energy Management Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 8
Reset counter: 16
Mileage: 42870 km
Time Indication: 0
Date: 2012.06.23
Time: 02:44:00
Freeze Frame:
Bin. Bits: 00000
Voltage: 12.70 V
Count: 17
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8T0 959 793 M HW: 8T0 959 793 D
Component: TSG FA H08 1401
Coding: 011C02624001450005
VCID: 53AF3C9E32EE691
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0135538600
Coding: 013B062220B904408020043680000000
Subsystem 1 - Part No: 8K0 951 177
Component: DWA-Sensor H02 0040
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Address 47: Sound System (J525) Labels: 8T0-035-223-ASC.clb
Part No SW: 8R0 035 223 F HW: 8R0 035 223 E
Component: DSP STD H11 0440
Revision: 00000000 Serial number: 00000000000001
Coding: 0203010102
Shop #: WSC 06325 123 12345
VCID: 2F67506E7E066D1
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 216
Mileage: 42841 km
Time Indication: 0
Date: 2012.06.22
Time: 20:16:27
Freeze Frame:
Voltage: 12.20 V
Temperature: 29.0°C
Bin. Bits: 00000001
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8T0 959 792 M HW: 8T0 959 792 D
Component: TSG BF H08 1401
Coding: 011C02224001450005
VCID: 52A1399A0DF4609
Address 53: Parking Brake (J540) Labels: 8K0-907-801.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 00000000755293
Shop #: WSC 00000 000 00000
VCID: 346D5F0297204E9
Address 55: Xenon Range Labels: 8K0-907-357.clb
Part No: 8K5 907 357 B
Component: Dynamische LWR H02 0010
Revision: 00000001 Serial number:
Coding: 0000001
VCID: 39736E367042B31
Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
Part No SW: 8T2 035 186 P HW: 8T2 035 186 P
Component: Concert3 H06 0350
Revision: 00000010 Serial number: AUZ5Z6J1469444
Coding: 050200820104CD00015B870900
VCID: 458B12C6CCBAC71
Subsystem 1 - Part No SW: 8T0 919 603 F HW: 8T0 919 603 F
Component: Display
2 Faults Found:
03157 - Functionality limited due to Communications Disruption
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 6
Fault Frequency: 48
Reset counter: 231
Mileage: 42841 km
Time Indication: 0
Date: 2012.06.22
Time: 20:16:28
Freeze Frame:
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 10000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 216
Mileage: 42841 km
Time Indication: 0
Date: 2012.06.22
Time: 20:16:31
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8T0 959 795 N HW: 8T0 959 795 B
Component: TSG HL H06 1401
Coding: 010C02224001450005
VCID: 56A9C58A211C7C9
Address 72: Door, Rear Right (J389) Labels: 8K0-959-794.clb
Component: TSG HR H06 1401
Address 77: Telephone
Cannot be reached
End ---------------------------------------------------------------------
Please can somebody advise on how I can get this to work? Many thanks
