So here's my problem.. "ASR Off" Light stays lit, indicating that I don't have stability control working. The vehicle with skid marks light also stays on in the instrument panel. Is this a common problem for the 2006 TDI's? The calipers and rotors were replaced right before I bought the vehicle (7000k ago), I thought it might be possible that the wiring to one of the wheel speed sensors wasn't connected properly and has just fallen off? Where are the speed sensors exactly? I have checked the fuses and when the rain lets up I'm going to check the wires going to the wheel speed sensors ... I'm waiting for my bentley manual to show up, hopefully it has info on how to test the actual sensors. Any help or insight would be greatly appriciated, I live in BC were there's lots of hills, rain and some times snow, so stability control does help on a regular basis for daily driving. Thanks a bunch guys, Trevor |
It's also possible that the wheel sensors was damaged, problem since you took ownership?
Also, get error codes so that you have a good idea what the problem is. Those lights would show up if you disconnected the battery but should go off. |
I actually baught the car in Ontario and drove across the country to BC and they it worked fine until I had been back for a few days...
The trip took a bight out of my wallet so I'll have to wait to get the codes read. Also, how hard is the timing belt on these? I'm should do it as well now that the car is at 120k km's. I did the timing belt on my scirocco and it wasn't too bad. I read the instruction that are on this site, seems i need some special tools, where can I pick those up? Thanks Trevor |
Timing belt is not too hard, the only hard part is supporting the engine to remove the motor mount. I rent the special tools but not to Canada, sorry. Shipping+duty is too much so it might be cheaper for you to buy them. There are some links in the writeup to sources.
So I bought a VAGCOM system and ran the autoscan, this is what it came up with.
Not too sure what the codes mean though... Friday,03,June,2011,19:08:55:36838 VCDS Version: Release 10.6.3 Data version: 20101206 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 1K0 Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D VIN: 3VWRT31K66M772845 Mileage: 120710km/75005miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 03-ABS Brakes -- Status: Malfunction 0010 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 56-Radio -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 7D-Aux. Heat -- Status: Malfunction 0010 ------------------------------------------------------------------------------- Address 01: Engine Labels: 038-906-016-BEW.lbl Part No SW: 03G 906 016 AB HW: 028 101 223 8 Component: R4 1,9L EDC G000SG 7550 Revision: --H01--- Serial number: VWZ7Z0F3302017 Coding: 0050071 Shop #: WSC 00066 000 00000 VCID: 63CEB308DBD3 1 Fault Found: 005697 - Please check DTC Memory of A/C Controller P1641 - 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 0 Fault Frequency: 126 Mileage: 113584 km Time Indication: 0 Date: 2000.00.00 Time: 04:21:49 Freeze Frame: RPM: 0 /min Speed: 0.0 km/h Load: 0.0 % Voltage: 12.08 V Bin. Bits: 00001100 Temperature: 33.3°C (no units): 16.0 Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl Part No: 1K0 907 379 P Component: ASR FRONT MK70 0105 Coding: 0017025 Shop #: WSC 00066 000 00000 VCID: 3F865F7817FB 1 Fault Found: 01314 - Engine Control Module 013 - Check DTC Memory ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 1K0-820-047.lbl Part No: 1K0 820 047 DQ Component: Climatic PQ35 090 0505 Shop #: WSC 00000 000 00000 VCID: 76E8FA5C7841 2 Faults Found: 00229 - Refrigerant Pressure 002 - Lower Limit Exceeded - Intermittent 00819 - High Pressure Sensor (G65) 009 - Open or Short to Ground ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl Part No SW: 3C0 937 049 D HW: 3C0 937 049 D Component: Bordnetz-SG H37 1002 Revision: 00H37000 Serial number: 00000000261167 Coding: 10018E234004180000140000001400000008730B5C Shop #: WSC 94788 999 54736 VCID: 2A501E2CFC79 Part No: 1K1 955 119 C Component: Wischer VW350 013 0402 Coding: 00065493 Shop #: WSC 94788 4 Faults Found: 00834 - Signal for Activation of Heated Rear Window 009 - Open or Short to Ground - Intermittent Freeze Frame: Fault Status: 00101001 Fault Priority: 5 Fault Frequency: 2 Reset counter: 63 Mileage: 65363 km Time Indication: 0 Freeze Frame: ON Voltage: 14.55 V ON ON OFF OFF OFF 01800 - Light Switch (E1) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 1 Reset counter: 63 Mileage: 120279 km Time Indication: 0 Freeze Frame: OFF Voltage: 12.50 V OFF ON OFF OFF OFF 00059 - Terminal 30 for Interior Lighting 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 63 Mileage: 120279 km Time Indication: 0 Freeze Frame: OFF Voltage: 12.50 V OFF OFF OFF OFF OFF 00975 - Heated Rear Window (Z1) 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00111100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 64 Mileage: 65359 km Time Indication: 0 Freeze Frame: ON Voltage: 14.55 V ON ON OFF OFF OFF ------------------------------------------------------------------------------- Address 15: Airbags Labels: 1K0-909-605.lbl Part No SW: 1K0 909 605 P HW: 1K0 909 605 P Component: 3D AIRBAG VW8R 032 7900 Revision: 03032000 Serial number: 0038FD0426AI Coding: 0013124 Shop #: WSC 00066 000 00000 VCID: 3972316009DF No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl Part No SW: 1K0 953 549 AH HW: 1K0 953 549 AH Component: J0527 034 0070 Coding: 0000021 Shop #: WSC 00066 000 00000 VCID: 78F4F4647255 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 1K0-920-xxx-17.lbl Part No: 1K0 920 852 P Component: KOMBIINSTRUMENT 3HL 4312 Coding: 0023303 Shop #: WSC 29252 067 57207 VCID: 36683A5C38C1 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 1K0-907-530.lbl Part No SW: 1K0 907 530 F HW: 1K0 907 951 Component: Gateway H10 0120 Revision: H10 Serial number: 2800105C13910C Coding: 3D3F0B40071002 Shop #: WSC 00066 000 00000 VCID: 2A501E2CFC79 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl Part No: 1K0 920 852 P Component: IMMO 3HL 4312 Shop #: WSC 00000 000 00000 VCID: 36683A5C38C1 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl Part No: 1K0 959 701 K Component: Tuer-SG 024 2377 Coding: 0001269 Shop #: WSC 00066 000 00000 VCID: 36683A5C38C1 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-14x.lbl Part No: 1K1 909 144 K Component: EPS_ZFLS Kl.5 D06 1701 Shop #: WSC 00000 000 00000 VCID: 336E03482BB3 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb Part No: 1K0 959 433 AF Component: KSG 0401 Coding: 137803281B09058F880F048051A0 Shop #: WSC 94788 999 91368 VCID: 74ECC0546E3D Component: Sounder n.mounted Component: NGS n.mounted Component: IRUE n.mounted No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl Part No: 1K0 959 702 K Component: Tuer-SG 024 2377 Coding: 0001269 Shop #: WSC 00066 000 00000 VCID: 377637583FCB No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 1K0-035-161.lbl Part No SW: 1K0 035 161 A HW: 1K0 035 161 A Component: Radio DE2 012 0015 Revision: 00012000 Serial number: VWZ4Z7F6132091 Coding: 0010400 Shop #: WSC 00000 000 00000 VCID: 1D3AC5F0BD37 1 Fault Found: 01042 - Control Module; Not Coded 000 - - ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl Part No: 1K0 959 703 D Component: Tuer-SG 021 2434 Coding: 0000144 Shop #: WSC 00066 000 00000 VCID: 31620940D1AF No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl Part No: 1K0 959 704 D Component: Tuer-SG 021 2434 Coding: 0000144 Shop #: WSC 00066 000 00000 VCID: 3260064CD4A9 No fault code found. ------------------------------------------------------------------------------- Address 7D: Aux. Heat Labels: 1K0-963-235.lbl Part No SW: 1K0 963 235 E HW: 1K0 963 235 E Component: PTC-Element 0404 Revision: 00800000 Serial number: Shop #: WSC 00000 000 00000 VCID: 2D5A1530CD97 1 Fault Found: 00361 - Heater Element for Auxiliary Heater (Z35) 014 - Defective End --------------------------------------------------------------------- |
Those are intermittent electrical faults. Clear the codes and see what comes back, if it doesn't come back then I wouldn't worry about it. The ABS light is on because of this fault in the ABS module:
1 Fault Found: 01314 - Engine Control Module 013 - Check DTC Memory Here is what the ross tech site says about it: http://wiki.ross-tech.com/wiki/index.php/01314 Quote:
Yeah, but it's a pirated one.
![]() -Uwe- |
Remove a front wheel, and you'll see the actual wheel sensors and their wiring harnesses. I broke the wires on mine from using cable chains to get unstuck last winter. The clearance between the tire and the wires is not very much. The wires are easy to see, if they are compromised in some way, or just unplugged.
I installed in a new wiring harness for mine, because the wires were snapped off too short to splice. Otherwise, it would have been a simple thing to splice the wires and protect it with heat shrink. My sensors were fine. |
