I would have thought there would be a manual adjustment, copied from VWvortex.
Thanks Keith, I was able to find the mk6 post but not the vortex post...
The two allen bolts I found were the ones shown by spockcat, which are BOTH lateral adjustments according to his post, not one vertical and one lateral like bubuski states, and I thought. I didn't look very long, but couldn't find the vertical adjuster in spockcat's post, I'll spend some time on it this weekend. How does the adaptation/adjustment option work, all headlight movement is controlled by sensors in the suspension, right? I don't want to blind on coming traffic, so after I figure out the proper and complete way to adjust these, I'll take it in to someone with a aiming machine. Unfortunately, I don't trust our dealer to know the proper way to do anything! We live out in the country, so my wife's chances of hittin a deer is more of a when than an if. |
Well I just
golf xenon headlamp adjustment then added mk6 and those were on the first page.
Thanks again, I guess I did find the vortex post but saw it in the Touareg forum and didn't read on.
However this seems to be it! http://wiki.ross-tech.com/wiki/index...enon_with_AFS)) |
Hi Everyone,
Thanks for all the irrelavent information concerning my model . Golf Mk6 2011 , with standard Halogen bulbs and manual height adjust from cabin . I worked out how to do it after much back pain . The two Allen key screws in white plastic do adjust height for both high and low beams , and the lateral for the low beam . How do you go about it ? 1 . Set your inside cabin knob fully raised . 2 . Use the allen key to get the required height for the low beam cut off . This adjustment will also affect the height of the high beams . They will probably be too high now , pointing upwards . 3 . There is an adjustment knob behind a small 2 cm rubber cover found just below the high beam cover opening . Take a 4mm socket and turn this screw . It is an auxiliary adjustment that can be used to adjust the high beam only , after you have adjusted both beams with the previously mentioned Allen key Result , No more gaps between the high and low beam , unless you're heavily loaded and have lowered your dipped low beam to avoid blinding oncoming traffic . The cabin control only works on the low beam and does not adjust the high beam . Great Forum |
![]() Cheeky sod.
