I was wondering if there are any solutions for these problems: Is there ANY way to get the SKC code from the dealer, or any other entity, in order to be able to use the VAG COM software to program my keys Is there ANY way to bypass the immobilizer system temporarily so that I can drive the vehicle to the dealer for reprogramming? (the towing is close to $500) Are there any other solutions/suggestions that might work? I am even thinking of trying all 10,000 combinations of the SKC code just to make this work. Thanks. |
There are a few master locksmiths out there who have the equipment and knowhow to retrieve the SKC and cut/program new keys. Phone around...
How far away from town are you that a tow will run $500 ??? You could rent a U-Haul trailer dolly and hire someone with a heavy-duty-enough towing setup for a lot less... Do a search on Vag-Tacho - to see if any versions can access your model car... Good luck !! Yuri PS: once you get this straightened out... are you aware of the balance-shaft-assembly design flaw in your vehicle? Read up on it in the 1000q section here... |
See the immobilizer FAQ and mk4 Key FAQ for some answers, to start, no the dealer can't give the skc to you because they never see it. I don't know how to temporarily bypass the immo. Someone told me that if they had an old working key and immediately used a new uncut key that it started once but I don't see why that would work and have not verified it. If it worked you probably wouldn't be asking your questions.
How did the chip break anyways? It's glued inside the key. |
