Old 07-29-2012, 07:38 PM
Car: audi a4 tdi, 2000 facelift
Default Immobiliser in the Dash?
Hi all, I just bought a 2000 a4 facelift, and took off the binnacle to push the rev counter needle back on, but when I put it all back together, it wont start and the immobiliser light is on? Have a buggered it up or can I reset it somehow???
Old 07-29-2012, 07:43 PM
I take it you had the clocks disconnected? Maybe try disconnecting the battery and touching the leads together then put them back on and see if that works. They don't normally need reset but they don't really like it if you unplug the clocks with the battery connected.
Old 07-30-2012, 02:31 PM
Hmmm disconnecting the battery and leaving it a while was the next step, touching the leads together? I suppose to ground it? This happend the day I fekkin bought it, needs new clocks anyway! But I just wanna be able to drive it to get work done to it!:-(
Old 07-30-2012, 05:19 PM
Disconnecting both battery and holding both leads together will ground them the idea is it discharges any capacitors in the electronics.
I'm sorry but this quick fix rarely works I think I've only heard of one or two users on here that it worked for.
Old 07-30-2012, 11:16 PM
It's how you reset certain clocks Keith, the motometer ones especially, they can go weird if you don't disconnect the battery before messing with them. Ask me how I know lol
You can reset the VDO ones with vag tacho though, but pulling the fuse or disconnecting the battery is a lot quicker.
Old 07-31-2012, 05:57 AM
Is this called a 'terminal 30' reset? may it wipe the stored Key data? Sorry to sound like rookie but its me 1st audi after 10 yrs of peugeots, and I havent a clue about pin numbers and how to get them and all, Iv only driven the car about a mile and now its just a big green paper-weight.
My plan today...disconnect the battery for 10 mins then check, failing that, disconnect battery and touch the leads to clear the capacitors and check...
Old 08-01-2012, 10:20 AM
Default Fixed!!!!
The only combination which suddenly fixed this after all the dissconecting and touching of cables, was to turn the ignition on, and while its dinging and flashing...disconnect the battery, keys out, leave it a minute, reconnect, and it was fine...? Thanks for all the input guys...:-)
