Old 05-24-2012, 01:04 PM
Car: VW Jetta TDI / 2002
Default Hello from Libertyville, IL
Hello to all:
2002 Jetta TDI, 201 K. Working on replacing the VNT Turbo Actuator (JasonTDI just did my 200 K Timing Belt, and told me mine was failing). Already have the new part in hand from idParts, but was wanting to look at the How-To here on this site.
Hoping this also "fixes" the strange Loon-whistle sound that comes from that general vicinity when the car is shut down in high humidity / high heat conditions -- but that is a shot in the dark for now. Might actually be an AC problem.
Other things that need doing: replace Passenger side door switch / sensor -- DOA; replace antenna base (starting to loose AM, and some FM); replace plunger that opens the trunk via the remote or door switch (it stops working whenever outside temperature is above 85 or so).
Cheers!
Old 05-24-2012, 02:34 PM
loon sounds like something either related to anti shudder valve but AC is also a good guess.
Old 05-20-2013, 10:03 AM
Car: 12' Ram 2500 Cummins QC, LB, 4X4 Big Horn
It is likely the ASV releasing the pressure after the shut off.
