Has anyone the answers to these questions . . . . Firstly if the oil pressure was so low and it was started only to check the oil pressure in the garage is there a chance that the turbo might now be dameged and it will fail later. The low oil pressure light did not come on while the car was ticking over but did at a slightly higher rev . . . The pin was just starting to slip but is was well and truely bad at this stage . . . If it helps the engine code is BRE. Would the oil pump need to be changed at 80,000 miles as is on the car at the moment now that the assembly is out?? If so is there a recommended oil pump change interval for same?? I believe the price is around 180 euros. The brake pedal going hard at the same time seemed very strange to me . . any suggestions?? Does anyone know where the balancer? connected to the pin to the pump can be sourced to replace the original on its own . . . i persume if i go to scrap yards i will have to buy the engine, take it out and apart and then see if the part i need is actually any good?? Any help would be so much appreciated, im outta my depth here and could do with some help. . . I believe at the min if i can sourced a new original replacement that all will be fine for the moment and this will get me back on the road. Please read and comment . . . Thanks, Noel |
VW Passats have the same exact problem. You have to replace the whole balance shaft module: http://www.myturbodiesel.com/1000q/b...passat-tdi.htm This article explains it all. I would just replace that and if the turbo fails later, replace it then. Good luck.
There is no schedule of change for the oil pump since it's supposed to be a life time part.
There is no replacement pin, it's worn. Swap the whole thing to the gear module instead of the chain module and be done with it. I agree, I wouldn't replace parts until they're broken or unless you think they're broken. As long as it was shut down fast, the turbo could be OK. |
The drive in thias engine is a gear drive which i hear is better than the chain drive. . . is there anywhere i can buy a replacment balancer part that is connected to the metal pin?? Thanks for the replies to date
It already has a gear drive? Are you sure? I don't see BRE engine code for 2006. I see BKE and BPW.
The VW parts catalog does not list the balancer parts, only the balancer module as a whole. |
Did you read the FAQ article? There's a magazine scan about the drive pin stripping. The brake pedal probably got hard because the engine wasn't running. If you step on the brake pedal a few times with the engine off the pedal gets hard.
so i could buy one of the two balancer shafts concerned. My local main dealership in Galway said they are no longer available anywhere and I must buy te complete modified unit for 1350 + vat . . . . ????
No, i have to admit that i am new to this site and did not loook into that. The brake pedal gets hard even when the engine is running and leaves it with practically no brakes. The only time that it ran is when i was pulling in when the light came on the first day and when checking the oil pressure on the guage . . . . . Thanks for your reply
You must buy the whole module. Sorry but this is a common pain shared amongst many. I don't know where you could buy the components since it comes assembled.
The hard brake pedal could be a bad brake booster, bad vacuum pump, or popped vac hose. |
The brakes only went hard when the low oil pressure light came on . . looks like its going to be dear unless i can get a part ![]() any suggestions please before i buy the entire unit today . . . PLEASE
