Go Back   VW TDI forum and Audi TDI forum - myturbodiesel.com > myturbodiesel.com forums > Audi Q7, VW Touareg TDI, and Porsche Cayenne diesel forum
Old 03-24-2012, 01:54 PM
Car: Toureg, TDI Lux 2012
Default Steering wheel shake VW Touareg TDI lux
I have a new Toureg, TDI Lux, 2012 and on the highway the steering wheel shakes. It happens around 65-85 mph, going straight, smooth road.
The dealer when first told about the problem balanced the tires. It didn't fix the problem. Next they road forced balanced the tires, didn't fix it. Then they took it to a tire shop that they say has a better machine for balancing. It didn't fix it either.
First they said, the tires are defective, then they said it's normal for vehicles with a truck chassis to shake like that. I don't believe that it's normal to have the wheel shake like that.
Has anyone had a similar problem and how was it resolved?
Old 03-24-2012, 01:57 PM
Not normal, PS spelled "Touareg"
Old 03-24-2012, 04:09 PM
Car: 2013 Porsche Cayenne Diesel
Mods: BlueSpark Pro + Boost
Send a message via Skype™ to grohgreg
Steering shake usually means front. Wheel bearings whine in slow speed turns. If it was a rim, they should have seen it wobble on the balance machine. If it was a simple matter of balance, the problem would more likely be down between 50-60 mph. Not sure they even spin the balance machine faster than that. Given that your issue starts at a faster speed and persists over a wider range, I'd go with bad tire or tires. They should be under warranty for the 1st year - right ?
//greg//
2011 Touareg TDI Sport w/full tow package (traded)
2013 Porsche Cayenne diesel w/tow package
Old 04-28-2012, 06:54 PM
Car: 2012 Touareg TDI Executive
I've had the exact same issue in a 2012 Touareg TDI executive I purchased 2/13/12. Same story - first I was told it was the "rubberized" highways in my state causing the shaking, took it to another dealer and I went through your same process of balancing, road force balancing, taken to another shop, then they replaced all 4 tires (tires not the rims)....still not fixed. I talked to the service manager and they have another 2012 Touareg currently at the shop with the same problem - apparently a service rep from VW is there trying to diagnose the problem. I'm taking my car back in Monday and if it can't be fixed I'm going straight to a lawyer to file a lemon law. No way I'm paying 57k for an SUV that shakes on the freeway. Period.
Old 07-23-2012, 04:32 PM
Car: Touareg/2012
Default Same issue
Just had my 2012 Touareg returned from another week at the dealer on this steering wheel vibration/oscillation issue. This is the 3rd tour of extended testing at the dealer. This last time a VW QTM supposedly involved. Previously, re-balance and alignment and subsequently switched off the stock Pirelli's to Michelins with new rims. No resolution. I own a LUX model and was given an Executive this past weekend for an extended 800 mile trip. Same problem in this model and admission that others they have tested do the same. My return resulted in "must be the nature of the beast"! and no resolution. If anyone comes across the problem causing this issue or finds a resolution most interested in having it passed along. Next step is to investigate 3rd party services and possible lemon law resolution. Accumulated nearly 3 weeks of dealership service time.
Old 08-04-2012, 07:54 PM
Car: 2012 touareg
This does appear to be a "characteristic" of the vehicle. The vibration/wobble, while exhibited primarily in the steering wheel can also be felt in the seats as you are driving. It occurs on smooth or rough roads and it can be intermittent, smoothing out at times. I've gone through every step mentioned below. Multiple balances, dynamic road force balance, new tires, new dealership balancing equipment and dealing with the VW corporate in Michigan. Each time I'm told they road tested and the problem is solved. I leave the dealership and its immediately apparent the problem is still there. The intermittant nature of the problem also seems to indicate it is not a tire or wheel balancing issue since that usually occurs at a certain speed and with consistency. The bottom line is that there does not seem to be an answer from VW to resolving the problem and I'm guessing that it is unfortunately part of the engineering design. I've driven another 2012 Touareg lux, and it has the exact same problem. Too bad.. it is one of the nicest auto's on the road today, but to pay 55K for something that vibrates like that is not acceptable.
Old 08-05-2012, 08:27 AM
More like coincidence I'd say. Two for two doesn't make an issue a characteristic. Now if a few dozen others chimed in here and said "mine too", you might have a case. FWIW mine has ~17k miles, and has never once exhibited the issue you describe.
//greg//
Old 08-20-2012, 01:02 PM
Car: 2011 VW Touareg Sport
My 2011 Touareg TDI shakes as well. I had it in 3 times to a dealer in Michigan. The demo I drove didn't shake, that I recalled.
My original tires were Goodyear Eagle LS and shook like crazy. After two times into the dealer, I demanded the Pirelli Scorpion tires that were on the demo, and they swapped them.
It shakes now that I've rotated the tires at 8000 miles.
The dealer told me they should never put performance tires on a 5000lb 'truck'... so maybe that's it? They also always fill the tires to 45 or 50psi, way above the 38psi recommended... I wonder if they know there is an issue and the high pressure mitigates it?
I've had a few issues with this, my virst VW, and have mixed feelings about it. Not happy a $50k vehicle shakes but I do love the tow capability and fuel mileage of the TDI.
Other issues (while I'm on my soap box):
- brakes were warped upon delivery! Had them turned and eventually replaced.
- BSR on IP center door, and mylar tape that we put on one of the latch hooks remedied that
- rear doors mysteriously lock while I'm driving? It's happened 3-4 times. No key fob in my pocket... no leaning on the switch.
Old 09-10-2012, 11:36 AM
Car: VW Touareg TDI Executive
Hello - I have a 2012 VW Touareg TDI Executive and noticed the same intermittent vibrations between 70-80Mph. The dealer said there have been no complaints about this, but would research it for me. I have not yet left it for service.
Interesting, I traded a 2010 Audi A4 that had a similar issue. The resolution was replacing the control arms (which was a defect in 2009) but to get to that point, it took 5 visits to the dealership and 5 sets of tires.
I don't want to go through that again, so any information on the resolution of this problem is greatly appreciated.
Thank you!
Old 02-13-2013, 03:49 PM
Car: 2012 VW Touareg TDI Lux
I have the same problem on my 2012 Touraeg TDI Lux!!!
I thought it could be the Michelin's that came from it from the dealership. I bought it used with 16,000 and change on the clock and it does vibrate between 65 and 80 quite consistently.
Could this defect have anything to do with the electric assisted steering?
I smell a RECALL. Come on VW! Take care of your premium car buyers!
