Go Back   VW TDI forum and Audi TDI forum - myturbodiesel.com > myturbodiesel.com forums > Audi Q7 TDI and VW Touareg TDI forum
Old 09-28-2011, 06:48 PM
Car: 2010 Audi Q7 TDI
Default Low AdBlue Light
Dealer just updated the ECM software, Campaign 23H3. After that was done, that low AdBlue light came on showing 250 miles. Somehow, I thought that 1500 miles was supposed to be the first warning.
At any rate, I added a little over 1 gallon of AdBlue fluid; and the llow AdBlue light and 250 miles remains on.
Does anyone know if it takes a while for that light to go out, or did the ECM software update somehow flummox something?
Old 09-28-2011, 09:02 PM
Car: 2001 jetta 2002 jetta
Mods: none
how many miles are on the vehicle ? it holds enough adblue to drive 10k and it holds alot more than 1 gallon, after we fill up during a service we have to use the scan tool to reset the interval.
Old 09-29-2011, 12:25 AM
Someone said you have to add at least a gallon and leave the ignition on for at least 30 seconds, I don't think it was you otherwise you'd have already done that!
Old 09-29-2011, 06:13 AM
The requirement to use a scan tool to reset was supposedly eliminated in later software updates.
There have been reports (?)here(?) that the low level light goes out after simple additions of the AdBlue fluid.
Of course, that still doesn't explain why it shows 250 miles on the first indication by the light, when it's supposed to have been 1500 miles.
Old 09-29-2011, 09:55 AM
Ross Tech provided me with an unverified procedure to clear the warning using the VAG-COM. It worked.
Since it is unverified, they do not want it published on the forums.
Looks like the deal is that, once the warning is triggered, you have to use the scan tool to clear it. If the warning is not triggered, you can add the AdBlue fluid to your heart's content for as many miles as you travel; and that warning will not come on - just as long as you stay ahead of it.
Also, it appears that this ECM software update has changed the warning interval.
