Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb I did a quick drive and watched the RPM, MAF sensor values, and Engine load (bank 3). Initially the MAF requested matched the Actual and the Engine load seemed responsible. Roughly 30 seconds after I started the car the Engine load got pegged at 100% and the MAF actually tracked at roughly double the requested value. This seems like it is probably related to the exhaust pressure control valve being stuck open. Are there any suggestions on possible solutions to fix this? Where is the valve located and is it possible to clean? Thanks for your help, Ian |
I think it's the backpressure valve mentioned here: http://www.myturbodiesel.com/1000q/D...AQ-VW-Audi.htm
![]() EOBD II Error Code: P047F Fault Location: Exhaust gas pressure control valve - valve stuck open Possible Cause: Wiring. Exhaust gas pressure control valve. Mechanical fault. Engine control module (ECM). As taken from my Free EOBD II Error Codes software
How much would it cost to replace this valve? Is it something I can do my self. Thank you
![]() It shouldn't cost Ian anything to replace the valve its a warranty claim.
Even if I am way past the 36,000 mile warranty? Thanks.
Well the UK warranty is 60,000 miles or 3 years so why is yours less?
It is 3 years 36,000 miles in the US. I am at around 59k right now. I still havent gotten this fix as the check engine light keeps coming of and off. It seems that when the tempertue rises to above freezing the check engine light comes back on (P047F every single time). Is there any reason behind this? I have not noticed a drop in preformance.
I got the same code. My dealer said it's a pretty common fault on the TDI. Fortunately, my car is still under warranty (@34.6K mi), otherwise, it's about a $600 valve according to the service advisor.
(off the record, he said he wondered why VW hasn't issued an extended warranty notice on this, kind of like they did for the window regulators on the Beetle, or heater cores on the mid-80s Golfs/Jettas). |
Is it safe to assume that they would cover under the bumper to bumper(3yr/36mi), but not the powertrain(5yr/60mi) warranty?
