hmm...without actually being there when this happened its hard to speculate. I'm thinking two possibles:
Maybe an iced/thawed inter-cooler maybe hydro-locked it without causing obvious damage? Or it may be possible that the immobilizer could have been to blame for the no crank and stall scenario. Anything light up on the dashboard that normally doesn't during this? Anyone else think it could be the immobilizer, or would you rule that out?
Came with: Sunroof, BT, Dynaudio, Cold Weather pkg, Blue Graphite Metallic, car purchased new 8/10 - approx 35000 miles now Upgrades: "Euro"switch, Comfort window feature enabled, fog lights as DRL, heated seat memory, 9w7 BT, auto hatch open, side mirror puddle lights, door warning lights, rear footwell lights, DieselGeek shift kit, winter snow tires used (I switch to indirect TPMS), aluminum kickplates, monster mats. |
bdisco posted while I was typing...yeah iced/thawed intercooler strong possibility...I'd look into it. You're lucky the engine runs, but there was for sure some sort of internal damage
So it did turn over and start initially so it wasn't hydrolicking from ice of the intercooler. What was the ambient air temp this morning where you live?
I've never timed it with a stop watch but an immobilizer on will let it start for about a second then cut out. You can start it again for another second then it cuts out. You say there was no engine check or immobilizer lights on. As golfTDI1 says it difficult to diagnose without being there.
oh nuts...I just tried to start my car to go get some DOT4 brake fluid among other things and do some food shopping. brent4727's problem pretty much happened to me:
1. Started the car, ran for abt 3 or 4 seconds (smoothly though) and just stopped abruptly, as if I had killed the key. All dash lights died too and then came back to life, radio clicked through the CDs and phone disconnected and reconnected. 2. I waited abt 10 minutes before starting again hoping that if it was I "hydro-lock" type issue that some of the pressure might dissipate, though I know this is unlikely. Tried to start, did about 3 chugs only and stopped, I released the key. 3. Tried getting the hose to the intake off to see what I could see...that was not possible without getting more tools and really digging in...im not prepared for this now. 4. Almost 15 minutes after the last attempt I tried starting again, about 4 chugs (seemed a little slow too) was all I could get. I immediately tried the key again and barely got 1 chug. 5. Tested the battery voltage: 12volts 6. Now, I'm waiting for the laptop to charge :/ so that I can do an auto-scan with VCDS. If depending what I see or don't see will determine where I go from there, but this looks like its going to result in a phone call to a tow truck and my VW dealership, I cringe at having to bring this car back to the dealer for the first time...I was hoping for it to go a lifetime without it seeing the inside of that shop :/
Weird, I am not knowledgable enough to offer any assistance, but I will post what my dealer says and would appreciate if you do the same.
30F thats cool but I wouldn't have thought the intercooler was frozen as I've said.
And golfTDI1 has had the same problem, strange two the same in one day. 12v is low for terminal voltage.
Well I just had it towed to the dealer :/ , we'll see what they say. Ill update this post as necessary...
