Old 10-26-2011, 01:25 PM
Car: VW Jetta sedan/2011
Default Installaction of OEM backup aid sensors ?
I purchased VW part 1K0 054 630 C, "Original Park-Distance-Control", to install in my 2011 Jetta sedan (the part is also listed to fit the 2011 Touran).
The design has a computer mounted in the trunk, connected to four sensors that must be inserted into the bumper (after being painted to match).
My question is, how to install the sensors ?
The instructions are illustrated, and there are no measurements provided, no template.
I wonder, is the inside of the bumper pre-marked for the four drill points ? If not, I wonder how to do this, not knowing the detailed sensor field-of-view to properly space them for optimum performance. The senors do have a notch to better ensure they point 'up' -- again, this is dependent on the installer making the notch in the proper location.
TIA
Old 10-26-2011, 02:03 PM
Well you can either guess the distances apart or measure them of a Jetta fitted with them.
The part number for the mk6 Golf is difference with or without the sensors so the holes are shaped and reinforced.
I assume you have VAG-COM/VCDS to code them?
Old 10-26-2011, 02:52 PM
Thank you for the welcome and suggestions.
I didn't think they'd be connected to any ECU and so wouldn't need to be coded. That said, yes, I do have the VAG-COM/VCDS that I purchased to get rid of the annoying horn beep when locking the car. The loud clicks on all four doors and light flash is plenty confirmation for me. :-)
Old 10-26-2011, 04:32 PM
FYI, there's a writeup contest Writeup award gift certificate through sponsor KermaTDI so if you want to share the DIY and document it, please do!
Old 10-26-2011, 04:56 PM
You are right there is no coding shown in Upgrading of Volkswagen Park Distance Control (PDC) to Optical Parking System (OPS). That is one thing I should have ordered with mine after driving it for a while.
Old 11-04-2011, 01:26 AM
Car: 2012 WV Jetta SportWagen
I was looking to do the same thing with my 2012 SportWagen so I was curious about if or not you found the bumper to have marks for sensor placement or not; have you gotten to the install yet?
Old 11-07-2011, 12:45 AM
No, I haven't yet gotten to it -- and will probably wait until next spring at this rate, with an extended out-of-town trip coming up.
I'll be looking for specific help, as in steps, to remove and replace the bumper.
