100% yes it'll throw error codes. I don't even think it would run well without it since the computer might send the car into limp mode if it doesn't get expected feedback from the various sensors. You have to have an engine tuner delete it in the software. Part of it is that the exhaust self clean cycle will be dumping fuel into the exhaust without the DPF in place. Here is more on the system: http://www.myturbodiesel.com/1000q/D...AQ-VW-Audi.htm
FYI, the car's emissions will go way up and if you have state visual or smoke inspection you'll definitely fail. EDIT: Yes it will run, I was told that the car would go into limp mode but it appears not. |
----- the fuj. |
Both physical and software. I don't know how the engine would run if you just cut the DPF out but I know it won't run right without the software accounting for it. |
Soot is the result of incomplete fuel burn, which is an inherent part of burning diesel fuel: it burns slowly, which is a challenge for piston diesel engines since they require rapid, frequent combustion events to produce power. The DPF stores soot, and the regen cycle adds heat (by way extra fuel into the DPF) t to "complete" the burn, which turns the stored soot into stored ash. The DPF has a finite life: when it's full of ash, it needs to be replaced. Little or no soot stored in the DPF is ever emitted. Removing the DPF will result in a huge increase in emissions, and the worst kind too, since soot is much more immediately harmful than greenhouse gasses. Also, unless you also remove the catalytic converters downstream of the DPF, I suspect that they would become clogged with soot rather quickly. |
Hmm thats something to think of since I'm sure an ECU re-flash will mean even more soot.
Just to clarify something, the DPF is a filter. The other things are catalysts. The construction of each passageway on the DPF is a dead end, meaning that it really is a filter. The construction of each passageway on the other catalysts are tubes. Some stuff can pass through them but too much can clog them as well. They were surely designed to work with the DPF so I don't know how much it would take to clog them.
Anyone have an estimated life-span for a DPF?
The end of life for the DPF is until it can no longer be cleaned, which is pretty much until the stainless steel hosing rusts out.
It must be removed and cleaned when soot loading reaches 45 grams. VW says to check it at 120,000 miles and every 10,000 miles afterwards. Take a look at the immobilizer page, on page 2 it shows how to check. |
