EDIT: here is a direct link to the buying guide summary: http://www.myturbodiesel.com/1000q/b...ying-guide.htm Size: although it looks similar, the cars are actually different sizes and shapes. Right off the bat, that should tell you that they are different cars. The North American car is 10 cm longer with a 9 cm longer wheelbase than the Euro Passat. NA specs: length:4,868 mm (191.7 in) wheelbase : 2,803mm (110.4 in) width: 1,835 mm (72.2 inches) Euro specs: length: 4,769 mm wheelbase : 2,712 mm width: 1,820 mm height: 1,470 mm luggage volume: 565 liters The rear C pillar, the area behind the rear door, is a completely different shape. In the 3rd post I made a comparison picture with more differences. Most if not all of the exterior panels are different. Engine choice: 2.0L 138hp TDI engine is the only TDI engine choice. Euro gets a 1.6 w/122PS, 2.0 w/140PS, and 2.0 with 170PS in TDI. Interior: standard automatic climate control. Euro has standard Climatic "semi-manual" with optional auto climate control US trim you have to press the fuel door *with doors unlocked to open it. Euro has an interior button for solenoid release. Premium stereo system in NA is by Fender. Didn't know they made car audio systems - not a knock but I've just never heard of them doing it. Euro stereo system, like Golf, is by Dynaudio. Good reviews. Lighting: halogen, maybe an xenon option later Euro has headlight range control, halogen, optional xenon, optional xenon foglights. Rear foglights are standard in Europe, will most likely not be on American Passat. The rear taillights are LED. The taillights are also a completely different shape. The NA car has more arched taillights. The Euro car has more square taillights. Other misc things on European VW Passat that aren't or most likely will not be on North American Passat: heated windshield, color multifunction display, automatic boot opening (boot=trunk, I think this feature opens the trunk if you put your foot under the trunk area - there's a sensor which then pops the trunk so you don't have to press any buttons), adaptive chassis control, start-stop, sport suspension (maybe), electric side and rear sunshades, rear view parking camera, lane assist, fatigue detection system, park assist (automatically parks the car), front-rear parking sensors, Last edited by chittychittybangbang; 01-10-2011 at 10:10 PM. Reason: updated info again |
Here are some pictures of the Euro Passat. If you compare it to the pictures in the link in the last post you can't see the size difference but it's there. The euro car also shows HID headlights and the LED taillights. There is also different trim like the chrome, bumper, and exhaust pipes (dual grouped vs. dual at sides). The Euro Passat has a chrome strip along the bottom of the trunk lid (boot), the NA VW Passat does not.
The interior shot shows a very different interior - the steering wheel and rear view mirror are the same but the dashboard, color MFD display,clock, air vents, range control switch or dimmer switch next to the headlight switch, keyless entry slot, electric parking brake, and the cubby aft of the shifter are all different. The door panels are also different. So although the exterior looks similar, the interior is basically a different car. Below are also some shots of the Euro Passat wagon to give you an idea of what the North American Passat might look like. |
Picture showing the exterior differences. At first glance I thought it was just a slight difference in size with similar headlights and different taillights. It's actually much, much more. Does anyone remember the "spot the differences" in Highlights magazine? Here you go.
The headlights are a completely different shape. The NA Passat has a little lip that makes the car smile, the Euro Passat has more of a frown. The edge of the lower grille also ends curved up instead of down. The NA Passat's bumper seam goes straight back from the headlight, the Euro passat goes down. The top and bottom rear of the front fender is also different. The front window ends in a point in the NA Passat. The chrome trim is different and lower in the Euro Passat. The rearmost window is a totally different shape. The rear door is a totally different shape. The rear taillights and bumper are a totally different shape. So yes Virginia, the cars are totally different.
I think the north american one looks a bit nicer, a bit chunkier with what looks like bigger wheels and I prefer the rear edge of the back door window too, it makes the roof seem slightly lower and a bit more edgy.
It looks like the NA car has Euro corners too. That is probably going to be orange on the production car.
Some more differences between the European Passat and North American Passat.
The Euro seats are sport seats, the US seats are comfort seats. This is not a US-Euro difference. However, the US spec Passat has the anti-whiplash headrests. The height is adjustable but the tilt angle is not. The Euro Passat has the Touareg/Phaeton headrests. These back of the headrest is fixed and the front slides on a 4 way axis to go up-down, forwards-backwards. The steering column trim of the US spec Passat has that horrible blank off spot for the ignition switch. Boo. It's a good feature, poor aestetics. At least the start-stop switch is integrated into the center column and looks OEM. The Euro Passat with Kessy has a steering column trim with no blocked off spot. It does however, have a slot for the key. The US armrest sticks out. The armrest of the Euro Passat is flush with the area underneath it. I can see a homelink transmitter in the driver's side sunvisor on the US Passat. The kickpanel trim is more pieces on the US spec car. The design of the NA dashboard and gauge pod is similar to the other US Spec VW. The Euro Passat is similar to the last mk5 Passat. The side view mirrors a different shape. The power side mirror adjustment is in a different location. The side window blowers are in the dashboard instead of in the A-pillar. The NA Passat has a door unlock button on the pass side. The door cards and center console are totally different. ![]() At this point I gave up marking the differences, there are just too many. They are different cars. However, this picture shows the difference between the headrests. Of interest is that the NA Passat has no spot for the bluetooth controls in the overhead console. The Euro Passat does (not visible), just like the Golf/Sportwagen overhead console.
This doesn't make any sense to me. They are able to have a more expensive Jetta in Europe with more features. If they wanted to cut costs, mass produce the same car and just keep the fancy headrests and color display in Europe. Whatever happened to economies of scale? If they can build the popular Sportwagen in Mexico and ship it to Europe, they can build the Passat and ship it to Europe too.
Chitty!
Great comparo : )
2Ø11 Candy-Weiß Golf 6 2,0 6-Gang DPF TDI BLUEMOTION Technologies™ Highline 4-Türen ▀ 2Ø11 Tornadorot Jetta 6 2,5 Highline 4-Türen ▀ Ø8 Deep Blau Perleffekt Golf 5 .:R32 3,2 DSG 4-MOTION™ 3-Türen ▀ Ø8 Tornadorot Passat 3C Variant Highline 2,0 TFSI ▀ Ø6 Tornadorot Golf 5 GTI 2,0 DSG TFSI 3-Türen ▀ Ø2 Indigo Blau Perleffekt Passat 3BG Trendline 1,8T 4-Türen |
Very good analysis of the new N/A Passat. Still some things I'm curious about...
1. Original info I saw stated the TDI would get a five spd manual and other reports seem to omit the manual info and only state the 6six spd DSG. The Jetta TDI gets the six, please give the Passat the six... 2. I also read that the 2.0 TDI gets a Jetta beating 43 MPG. Engine HP and torgue figures are the same for both and yet the Passat is bigger and I assume heavier. Does the Passat get an upgraded version of the TDI motor? What/where are the refinements? Just guessing/dreaming here
BTW I have the following to my credit
![]() 93 Golf TD 1.9L 97 Jetta TD 1.9L 2005 Passat TDI 2.0L 2000 Jetta TDI 1.9L I would still be driving the Passat today.. most amazing engine I have ever had the privilege but the 5 spd tip trans was junk. Not only did I hate it but my neighbours Passat also had it and it gave up at 110,000 km so I sold. |
