Old 03-24-2012, 04:53 PM
Car: Golf Wagon TDI 2010
Default Any thoughts on these error codes?
My car goes in for regular maintenance (135000km) and these are the codes I got when I scanned the last time. Anything I should know....?
Part No SW: 03L 906 019 CM HW: 03L 906 022 TS
Component: R4 2,0L EDC G000AG 7967
Revision: 12H03--- Serial number:
Coding: 0350078
Shop #: WSC 94829 999 15599
VCID: 78D132920BC86A3
2 Faults Found:
009571 - Turbocharger Boost Control Position Sensor Circuit
P2563 - 000 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 4
Mileage: 136720 km
Time Indication: 0
Date: 2020.14.10
Time: 17:20:17
Freeze Frame:
RPM: 805 /min
Speed: 0.0 km/h
Voltage: 13.91 V
Temperature: 204.0°C
Lambda: -16.6 %
Bin. Bits: 00001110
Voltage: 1.976 V
000175 - Actuator Module for Turbocharger 1
P00AF - 000 - Stuck - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 136720 km
Time Indication: 0
Date: 2020.14.10
Time: 17:20:19
Freeze Frame:
RPM: 828 /min
Speed: 0.0 km/h
Load: 0.0 %
Load: 100.0 %
Lambda: 20.5 %
Absolute Pres.: 1020.0 mbar
Temperature: -0.9°C
Readiness: 0 1 0 0 0
Thanks for any help...
2010 Platinum Grey Metallic GSW w/DSG
Old 03-24-2012, 10:24 PM
VAG Error Code: 009571
EOBD II Error Code: P2563
Fault Location:
Turbocharger (TC) boost control position sensor (G581) circuit
Possible Cause:
Malfunction Indicator Light (MIL) ON.
Wiring and/or connections faulty.
Turbocharger (TC) boost control position sensor (G581) faulty.
Engine control module (ECM).
Possible Solutions:
Check fuses.
Check wiring and connections.
Ohm test Turbocharger (TC) boost control position sensor (G581), see factory repair manual.
VAG Error Code: 000175
EOBD II Error Code: P00AF
Fault Location:
Turbocharger (TC)/Supercharger (SC) boost pressure control A - Module performance
Possible Cause:
Glow Plug light flashing.
Reduced engine performance.
Wiring.
Possible Solutions:
Defective Boost Pressure Control (N75).
Vacuum leak or low vacuum.
VNT sticking or seized.
Charge Pressure Actuator Position Sensor (G581).
Possible Solutions:
Verify Defective Boost Pressure Control (N75) is working to design, use Output Testing.
Verify vacuum lines are good, check engine vacuum at idle.
Test VNT and Charge Pressure Actuator Position Sensor (G581), apply vacuum to VNT and watch MVB 120.4.
Engine off, no vacuum 120.4 should read about 3.5V.
Engine Off, apply 17 Inches of mercury, 120.4 should drop to about .7V.
Engine at idle, 120.4 should read about 7.V.
If 120.4 voltage doesn't alter, VNT may be seized or Charge Pressure Actuator Position Sensor (G581) failed.
Old 03-25-2012, 11:16 AM
Keithuk
Thanks for the details, will use them when talking to the mechanic.
Old 03-26-2012, 08:15 PM
The are going to replace the Charge Pressure Actuator Position Sensor (G581) according to a TSB i never heard of... TSB 21-11-08?
Old 04-15-2012, 02:45 AM
Car: seat leon
Default unknown error code
Anyone got any clues?scanned my seat leon as it is going into limp mode,only fault stored was engine 4930 unknown error?? Car is 2.0 tdi bkd I have been pricing new turbo and weird as it is the part number for the turbo is]724930 any help would b great.
