Old 01-23-2012, 07:50 PM
Car: VW Golf 6 Wagon 2.0 TDI / Golf 4 TDI
Default 2012 VW Golf Wagon TDi - engine woundt shut down
Hi,
just bought it brand new, it has less than 200km and my wife called me few minutes ago, the engine wouldnt turn off. I had an old 1984 Merc 190Diesel, which would do that when was very cold and you want to turn off the engine after only few minutes after the first cold start, but now this is a new car and my wife had driven it for 50min before she wanted to shut down the engine. It stopped after 2-3 minutes.
Any ideas?
Old 01-23-2012, 09:36 PM
No offense but was the key out of the ignition? Do you have KESSY? The car is drive by wire so there's an electrical prob if not shutting down.
Old 01-23-2012, 11:45 PM
"No offense but was the key out of the ignition? Do you have KESSY? The car is drive by wire so there's an electrical prob if not shutting down."
I don't know if she took the key out. And what is KESSY? Just talked to her in a bit and she said everything was fine. I am sick of VW. I have had 6 so far and bought this one new, so i dont have to do repair. Its 2ookm and it started. Will buy ugly Corolla finally so i dont have worry anymore.
Old 01-24-2012, 01:21 AM
Car: 2012 jetta tdi wagon
Well good luck to you. Ya know it's still under a 3 year warranty right.
Old 01-24-2012, 09:23 AM
Car: 2011 Jetta TDI
Mods: 2011 Jetta-none, 2008 RAM Mega Cab lost the BlueTech emissions
Originally Posted by axios View Post
Hi,
Any ideas?
I have a question for you. Was the engine actually running or did she hear the electric fans running after shut down?
The reason I asked this is my wife said the same thing to me after we bought the Jetta. She had about 300 miles on the car and pulled into the garage shutting off the engine. When she was exiting the car she heard what she thought was the engine running with the fans on. She called me into the garage to listen to the car. I said the fans where on to cool off the cooling system since these are electric and will turn off after a preset temperature in the ECM.
The "KEYSS" system is keyless ignition and door locks. There is a push button starter and the key fob is either in your pants pocket or your wife's purse. The key just needs to be in the car in order for it to start.
Jim W.
11 Jetta TDI DSG Auto with Nava system, -Wife's
08 2500HD Mega Cab SLT, 6.7L CTD 68RFE,Optix Gauges Pyro,Boost,Trans Temp A Piller mount, Mag-Hytec Trans Pan, Front & Rear Diff Cover, Smarty, MBRP 5" Exhaust, Silver, Westin Side Steps, Line-X Spray in Bed Liner over the rails, Bed Cover, Prodigy BC, 15K Reese hitch and pulling a 11K 5er-My ride
Old 01-24-2012, 11:35 AM
Conrad -JSW's Avatar
Car: 2012 JSW TDI DSG Sunroof/Nav Silver/black
Jim W.
Actually, the fans keep running if the car was shut down during a regen cycle.
Old 01-24-2012, 05:06 PM
Car: 2012 WV Jetta SportWagen
Hi,
Any ideas?
My bet is that this was the fan running; especially if the car had done a regen the fan is (IMO) louder than the engine, or so it appears to me. 2-3 minutes is about what I've experienced the fan to run after you turn off the car.
Old 01-24-2012, 10:10 PM
Car: 2010 VW Golf TDI 6M 4dr
Mods: see signature
Yeah, this sounds like a cooling fan issue related to a DPF cycle, this is normal...it can really sound like the engine is still running. Dude, don't give up on your VW yet!
Came with: Sunroof, BT, Dynaudio, Cold Weather pkg, Blue Graphite Metallic, car purchased new 8/10 - approx 35000 miles now
Upgrades: "Euro"switch, Comfort window feature enabled, fog lights as DRL, heated seat memory, 9w7 BT, auto hatch open, side mirror puddle lights, door warning lights, rear footwell lights, DieselGeek shift kit, winter snow tires used (I switch to indirect TPMS), aluminum kickplates, monster mats.
Old 01-26-2012, 09:03 PM
Car: Jetta TDI 2012
What he said! Mine did it the first time at about 250 miles-got out and heard it "running"...thought what the h...? It was just the regen. No problem. Be sure and check this out before thinking the worst....
Old 01-26-2012, 11:51 PM
Car: Golf/2011
Yes, regen of the DPF was interrupted. Fans run to prevent melt down of the plastic bits in the engine bay. Normal operation. And now you know the rest of the story.
