Old 07-15-2010, 08:01 PM
Default 2011 - 2012 VW Jetta TDI reviews, FAQ, and buying guide
This article describes what's known about the 2011 Jetta TDI. Any reviews and updated information like MSRP or invoice pricing of options will be added as they come up. Right now there are some video reviews comparing the mk5 and mk6 Golf because the mk6 Jetta will probably get some of the changes that were on the mk6 Golf like thicker windshield, glass, more laser welding, and more NVH noise vibration harshness tuning.
Of note are the more curvy mk6 Golf style dashboard and mk6 side view mirrors that are now on the Jetta sedan TDI. My best guess is that the 2011 Jetta TDI sportwagen will keep the mk5 style side view mirrors for a while. There are supposedly significant differences that are under the door panel that aren't readily visible. This was one of the reasons why the Dynaudio was available on the new Golf and not the old Jetta for 2010. This may change for the new 2011 Jetta TDI.
Also, the RNS510 GPS system is still available on the Jetta. The RNS 315 GPS VW system is the replacement on the Golf but I see no reason why you couldn't add either one to either car as parts after your purchase.
http://www.myturbodiesel.com/1000q/a...de-reviews.htm
Old 07-16-2010, 06:45 AM
No more news on the coupe then,, I'll check the page again but list the changes as you make them so that it'll be easier to spot them.
Old 07-19-2010, 07:59 PM
Car: 2002 VW golf TDI
I was looking at the vortex's posts, take a look at this:
No gas gauge. It's in the display. The badge on the car said SEL but no full screen display?
Overhead bluetooth?
AHH!!! Where's the ignition switch?
Oh, there it is.
The return of the torsion beam
http://www.vwvortex.com/gallery/gall...oduction%20NYC
Old 07-20-2010, 04:15 AM
Car: 2005 jetta tdi
Mods: -
Wow. How much does the extra 1/2" of screen space cost? I actually like it when something is plain and simple but not when it looks like something is missing. That's what makes the ignition slot blank and the half screen look really cheap. Or is the ignition slot blank actually a slot where you have to insert the key?
Old 07-20-2010, 06:09 PM
article updated for most current info from the info in this thread:
Details and pricing for 2011 Jetta are here!
Here are some of the additions:
There are only 2 trim levels: TDI and TDI with the nav package. Dealer installed options like body kits or floor mats will be extra.
Standard TDI trim level:
4 wheel disc brakes, 16" "mambo" alloy wheels, trip computer, sunroof, RCD 510 touchscreen 6cd changer radio w/SD card reader, cold weather package (heated front seats and windshield nozzles), leatherette (v-tex vinyl) seats, leather multifunction steering wheel, parking brake, and shift knob, bluetooth, MDI ipod cable, Sirius radio, keyless entry, and 6 speaker sound system.
Safety equipment: front, side, and head curtain airbags, ESP (stability control), ABS, TMPS (tire pressure monitor sensors), LATCH (child seat anchors).
Navigation package ($1200 MSRP)
: this is the only factory installed option package on the Jetta TDI trim level. You can add dealer installed options like all weather floormats or body kits later. This adds: RNS 315 GPS navigation w/SD card reader, foglights, chrome trim on the grille and windows, keyless access with engine start button, and driver's seat lumbar adjustment. See 1000q: RNS 315 GPS FAQ for more info on the GPS system.
Official pricing for 2011 VW Jetta TDI sedan
Destination fee of $770 not included in the prices below.
MSRP in US$
6 speed manual VW Jetta TDI 22,995
DSG (auto) VW Jetta TDI 24,095
6 speed manual Jetta TDI w/nav package 24,195
DSG (auto) Jetta TDI w/nav package 25,295
Old 07-20-2010, 07:29 PM
After checking the numbers, the standard 2011 VW Jetta TDI (no nav package) will be about $1000 less than the 2010 VW Jetta TDI.
However, it loses such premium features like:
-independent rear suspension
-110V (household) outlet in the rear of the armrest center console (assuming this because it's not listed)
-removal of standard lumbar adjustment on driver/passenger seats. The nav package adds driver lumbar.
-water and fuel gauges - they are now in the MFD (instrument cluster display)
-VW Jetta trunk hinges used to be more expensive articulated units that took up less room (on left). The 2011 Jetta TDI (on right) now uses a simple arm hinge that swings inside the trunk when closed. The trunk also gets plastic and painted metal instead of full carpeting lining. Instead of trunk struts on both left and right sides, there's 1 trunk opening strut on the right side of the inside-roof of the trunk.
-shopping bag holder in the trunk (the cloth loop hanging down in the pic left). It's not clear if the 2011 has a similar device.
Old 07-20-2010, 10:17 PM
Is it just me or does the front edge of the trunk on the new style look really close to the glass?
Old 08-13-2010, 01:26 PM
Some more info from a post by Turbo Paul @ millenium vw , added to the buying guide.
The tire pressure monitor sensors are no longer actual temperature/pressure sensors in each wheel. It now works off a calculated value off the ABS sensors. If the wheel senses a decrease in rotating diameter, it assumes that it's deflated.
The seat back tilt control is now manual instead of electric.
The glove box is now dyed bare plastic instead of lined with felt.
Strangely enough, there's a full sized spare tire instead of a space saver spare. If you want to cut costs, cut the full sized spare tire.
Old 08-13-2010, 03:42 PM
Car: bmw z3 2002, vw jetta tdi 2010
Mods: stock
Good posts guys! Makes us 2010 owners glad we didn't wait.
Old 08-13-2010, 11:44 PM
Car: Golf VI
I wonder how this system would deal with a complete wheel/tire package, upgrade or swap, that is not exactly the original stock diameter?
hmm.
10' US spec. 4dr Shark Blue MK6 Golf TDI (140) DSG, Cold Weather, Sunroof, Dieselgeek Panzer Plate, WeatherTech FloorLiner™ DigitalFit® mats, 3M Clear Bra, Llumar CTX 40 ceramic window tint.
