Check out malone tuning, the car is so new though I don't know if he has anything for it, but you can ask.
IMHO, it should run fine on bio without the DPF. Of course, you're basically giving them a reason to deny warranty on engine, one of the most important things but the biodiesel pretty much does that already. |
Jim W.
11 Jetta TDI DSG Auto with Nava system, -Wife's 08 2500HD Mega Cab SLT, 6.7L CTD 68RFE,Optix Gauges Pyro,Boost,Trans Temp A Piller mount, Mag-Hytec Trans Pan, Front & Rear Diff Cover, Smarty, MBRP 5" Exhaust, Silver, Westin Side Steps, Line-X Spray in Bed Liner over the rails, Bed Cover, Prodigy BC, 15K Reese hitch and pulling a 11K 5er-My ride |
The National Renewable Energy Laboratory published an academic paper in 2009 which essentially acquits B20 from damaging the engine or DPF in a new diesel car. Please read the article (http://www.nrel.gov/vehiclesandfuels...pdfs/44833.pdf ) and let me know what you think. The article also indicates that after 120,000 miles of simulated operation with B20, the NAC (NOx) system in a car like the Jetta still passes Tier 2 Bin 5 emission levels. The article shows that the SCR (NOx urea) system in a car like the Passat does not pass these standards after simulated operation with B20. There is another NREL article which shows that the DPF is actually more effective at removing soot when operated with B20. I'm posting this message on a couple of TDI forums because I'm puzzled that no one else seems to have seen this 2009 article. Am I missing something? I know VW doesn't warrant B20, but perhaps the issue is not technical but political. I emailed VW, but because I don't have a Jetta yet I don't expect an answer for a long time if ever. Would someone who has a Jetta kindly forward the link to this article to VW customer support and see if there is a meaningful answer? Have their engineers actually seen this article?
VW has never approved more than B5 and I don't see them changing anytime soon. I'm sure their engineers know much more than they could publish due to liability and politics.
Thanks for the heads up on the SCR system and B20 note, I'll read it in more detail later, it's a very informative document and I may even add it to the DPF FAQ article and biodiesel section. |
