http://www.myturbodiesel.com/1000q/a...gine-index.htm LTC1967, you do not have permission to access this page. This could be due to one of several reasons: The members only section is for registered members. If you're trying to view the threads in the resources section in the forum you must have at least 1 post to view. Please post the problem you're having to gain access. It can take a maximum of 10 minutes for it to be processed so please search the forum or the extensive FAQ while you wait. Do not post a "blank message" or access will be blocked for 24 hours. A blank message does not let others help you and if that's what you want, that's what you will get. Please respect the forum rules. If you don't have anything else to say, just post a greeting with your location and what model/year car you have. Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post? If you are trying to post, the administrator may have disabled your account, |
All you had to do was join which you have so now you should be able to view it.
I have same problem, even though I am a member, still won't let me see it
Welcome to the forum guys.
![]() This is the first post for both of you which is generally done in Introductions, now you can access part 2.
